Results 1 to 4 of 4
Thread: Need info on drives
    Feb 2010
    Need info on drives
    Hi I am not new to here but I am trying to decide on new drives for my Taig Which I have Xylotec set up now but I am looking fo more reliablilty and some more speed and rapid like in drill paths.
    Thanks in advance
    bigguy
    Registered Jeff-Birt's Avatar
    Feb 2007
    The trick is having stepper motors, drives and power supply that all work good together. There is a tendency in the hobby community to fit large steppers thinking that it will increase performance (but it seldom does). I suggest/fit 'small' steppers to Taigs but get very good performance. Here is a video that shows how a Taig can perform (doing 90IPM rapids):
    http://www.youtube.com/watch?v=RzrBcXCNDhU]90 IPM SS - YouTube
    Jeff Birt
    Feb 2010
    Thanks that is inpressive.
    But I Guess I am looking for some suggestions. Like I can get deepgrooves Geko 540 or super-techs servos or there steppers. I would like to use servos but is the price worth it on a Taig with out changing the spindle motor.
    Feb 2007
    For a small machine like a Taig there is no real benefit to using servo motors. There is no real increase in performance or accuracy. The only thing gained is some amount of feedback so that if you are too aggressive on your feed rates the machine will fault. On a stepper system when you overload the drives they will stall. In either case you have asked the machine for more than it can provide and ruined your part. If you are loosing position on a Taig with stepper motors you have a poor drive system or are asking the machine for more than it can provide.
    G540 based systems are a good fit for Taig sized machines. You just need to match the stepper motors to the machine to get best performance.
    Jeff Birt
  1. Info Needed: Copley 306AP and Moog 152F427A drives
    By p27182 in forum Servo Motors and Drives
    Last Post: 01-23-2013, 11:19 PM
  2. Osai drives, info needed
    By Hood in forum Servo Motors and Drives
    Last Post: 12-31-2012, 02:20 PM
  3. Vexta KBL Drives & Motors Info
    By john.charles in forum Servo Motors and Drives
    Last Post: 02-09-2011, 09:58 AM
  4. Need Help!- Trying to find info on old Thompson Omni drives (full size)
    By langless28 in forum Controller & Computer Solutions
    Last Post: 04-09-2010, 02:36 PM
  5. Trying to find info on LINEAR DRIVES LTD controller
    By chriscain in forum Controller Cards
    Last Post: 10-14-2007, 04:46 AM
