Hi Folks,
Really new means I have not bought a
CNC milling machine yet. I have a Smithy 1324 3 in 1 combo that I use and a
CNC Plasma table that I build aircraft weather vanes with. But I have to rely on others for 3D items and since I'm a very small fry it's hard to get things made a few here and a few there. So it's time to step up and do it myself.
[That sounds like a good plan.]
I'm thinking that I'd like to buy a Taig 2019CR-ER. I already have my stepper motors, breakout boards, power supply etc.. And I've chosen CNCDesk as my entry level software. I do use TurboCad and Mach 3, but need to get smarter on 3D programming.
[The Taig is a nice little mill. If your parts fit in its envelope, it should work for you. I'm not sure about CNCDesk though - isn't that a DOS program? You might want to find something a bit more advanced, if you're putting in the effort to learn it. If you share more information about what your control system consists of, you might get some knowledgeable comments about it.]
Mostly, I have a requirement to cut aluminum and sometimes 4130 steel when I make parts for other experimental aircraft builders.
[As long as the steel's annealed, and you take it somewhat easy, that should work.]
I'm sure that even the newest of those amongst you are far more skilled than I. So I'd like to hear your thoughts about my choice for an entry level
CNC mill. I'm a retired guy with a home shop, not a daily production facility.
Thanks,
Glen Porter, Major USMC (Ret.)
Private to Major via CWO-4
1966-1990
