You can't measure backlash that way. What you need is a good test indicator mounted in the spindle. You 'preload' the indicator by moving the X-axis so that the indicator probe just touches your center stop and then keep moving toward the stop until the indicator has moved about 0.010" (ten thousandths). Now move the X-axis the opposite direction 0.001" (one thousandth) at a time. If you have no backlash of course the indicator needle would move back 0.001, in reality there will be some backlash.
Let's say you jog 0.001" three times before the indicator moves and it only moves about 0.0005" on that last jog. This would mean that you have about 0.0025" of backlash on that axis.
Hope that helps...
LinkBack URL
About LinkBacks
I can't move my machine manual. That is why I post here to get a different perspective so maybe I can see it more clearly.
