Results 1 to 3 of 3
Thread: Need some help with my taig
    May 2011
    So, I finally got my back to stop hurting long enough to finish my enclosure for my Taig DSLS3000. But now I've run into another problem, and an interesting one at that.
    I loaded up one of the demo codes that came with the machine, something that cuts the profile of a horse. I ran the code without the spindle on, nothing to cut, and no tooling. It ran great. So, I put in an endmill, loaded up a piece of wood, and turned on the spindle. Tried to run the same code again, it went to zero, then started making clicking noises and wouldn't move.
    I stopped the program, and tried jogging it around a bit. Worked just fine, not a catch in the world. Tried running it again, went to zero perfectly, then did the same thing. I am just getting into this, so I have no idea what could be wrong. I doubt it's the code, as the zero part works fine. It already ran through the ENTIRE code once, perfectly fine. Any ideas?
    Feb 2012
    England
    Ain't got a clue but it sounds like its saying I've completed this project and if you want me to do it again you must reset the project? turn off and turn on again see if that cures it
    May 2011
    Already did. Nothing.
  1. About to get a new Taig, need help!
    By Vicanic in forum Taig Mills & Lathes
    Last Post: 08-01-2011, 04:05 PM
  2. The right taig for ME?
    By granth3 in forum Taig Mills & Lathes
    Last Post: 12-26-2010, 04:02 PM
  3. Taig 3 Jaw Chuck on Taig Mill?
    By jim_stoll in forum Taig Mills & Lathes
    Last Post: 09-14-2007, 06:44 PM
  4. Taig CNC help
    By Grimracer in forum Taig Mills & Lathes
    Last Post: 03-13-2004, 10:32 PM
  5. EDM for a Taig?
    By teilhardo in forum General CNC Plasma And Oxy Fuel Cutting Machines
    Last Post: 03-04-2004, 06:36 PM
