But I'll try to help. Are you sure those are servos on your mill? Taig also makes a model (the DSLS 3000) with steppers equipped with encoders - could that be what you've got? The only Taigs commercially available that come equipped with servos are from Supertech: Super Tech & Associates Main Web Home Page Is that what you've got, or was this somebody's home-brew setup? C&CNC are also still around - you should ask them if you're having problems with one of their controllers: http://www.candcnc.com/ Does your controller have the Gecko stepper drives, or G320 servo drives? Are you trying to use Mach3, or some other control program?
Andrew Werby
ComputerSculpture.com — Home Page for Discount Hardware & Software
LinkBack URL
About LinkBacks
