Results 1 to 4 of 4
Thread: Collet size ?
    Registered speedtwin69's Avatar
    Oct 2009
    Collet size ?
    I have a Maxnc 10 and I am interested in knowing what you call these collets.
    Is it some ER ?
    Is Taig the same size?
    Banned
    Jul 2009
    us
    I am afraid it is not er16. maxnc actually just used the core of a taig lathe spindle iirc - they used to claim they were some special proprietary thing they built on their own, but they would actually apparently just buy lathe spindle rebuild kits from taig and repackage them into their own head clamp. this meant they used taigs old collet style, not the er16 style. so this makes things really easy if you just need replacement collets, as taig still sells those type.
    this also might actually make things easy for you if you do want to go to er16, as you could look into getting a taig er16 rebuild kit and collet set and seeing if you could simply swap the spindle core that is in there. just a guess, but its very likely pretty much a straight swap more or less.
    this would likely be a pretty easy way to get the er16 collets, but at the same time i am hesitant to say if the lesser runout of the er16 would solve any problem you might be having though; from my experience the maxnc10 was not a very rigid machine and tended to have a lot of flex and deflection under load, which may be where any tool breakage, dulling, or chatter you experience may come from, something not necessarily fixed by a more accurate collet type.
    Oct 2009
    My spindle is 5/8" dia., I'll probably just order me a straight shank end mill extesion.
    Perhaps DA200 series, for I have a hundred collets of any size up to 3/8" .
    DA collets are cheap and run very true.
    Feb 2008
    Quote Originally Posted by speedtwin69 View Post
    If it really is a Taig spindle then the spindle is 17mm where the bearings are mounted and 5/8" where the pulley is mounted. Cartridge bearings are almost always metric, and the Taig uses 6903 cartridge bearings (17mm ID, 30mm ID, 7mm tall).
    The ER16 spindle is nice and you can buy it alone. ER16 collets aren't very expensive and the wide clamping range is nice.
    alex
  1. ER16 Collet Size Problems
    By Bob La Londe in forum General Metal Working Machines
    Last Post: 02-08-2012, 12:24 PM
  2. Need help with collet size: PC Mill -30
    By oxford in forum Emco Mills
    Last Post: 04-11-2010, 10:41 PM
  3. Need Help!- Collet size for Logan 820 Lathe?
    By BioMicro in forum General Metal Working Machines
    Last Post: 03-17-2010, 08:08 PM
  4. Replies: 2
    Last Post: 12-30-2008, 11:14 PM
  5. What is this collet size?
    By kong in forum General Metal Working Machines
    Last Post: 06-06-2004, 02:07 PM
