Page 1 of 3 123 LastLast
Results 1 to 12 of 29
Thread: Backlash
    May 2010
    Backlash
    I'm working on getting a Taig 2019 Manual mill. I "grew up" working on a couple of Bridgeports with DROs, and I'm a complete slave to having one. I've seen that the "normal" way of doing it is cheap chinese calipers modded to work as linear slides. I'm considering eventually CNCing this, and I have two questions that are connected.
    Does the output from the chinese slides work similarly enough to a quadrature encoder that they could be used as encoders for a closed loop system? If not, is the backlash in the Taig low enough that you could reasonably use a rotary encoder on the shaft connected to a Shumatech 350 DRO and get good results? I don't want to spend a couple hundred on slides that I can't use since the Shumatech can take quadrature encoder inputs according to the website.
    At home I have a big closed loop CNC that I have converted from original control software to use EMC2, DC Servos on ballscrews, and it is rock solid. I've used a Taig on steppers and it's a solid machine, I just love the direct input of working on a manual mill. The second option is to use Mesa Electronics boards as if I were doing a CNC conversion and just skip the DC motors for now, since a closed loop system is considered optimal while driving all the axes though CNC, I expect that the encoders will be good enough for use with a DRO.
    Please feel free to tell me why I am wrong.
    hub
    hub is offline
    Sep 2010
    Finland
    Quote Originally Posted by efinkg View Post
    Just my opinion..
    Linear measuring would be best, but I'm not so sure "chinese converted calipers" would be it.. The "proper" glass ones are expensive though.
    I would go for the encoders if price matters.
    And if there is backlash, I would try to fix it mechanically if possible.
    Just my thoughts
    Hub
    http://www.cnczone.com/forums/cnc_wood_router_project_log/125895-my_diy_cnc_cnc2011_%3B.html
    Feb 2008
    There isn't a lot of room on the Taig for glass encoders.
    If you are eventually going to go to CNC then I don't see much reason to put a DRO on first. There isn't much equipment which can be shared between them. Few Taig CNC conversions (or small benchtop machines in general) are closed loop. I also like manual machines, but if I have to have one big machine and one small machine I'd prefer my small one to be the CNC, not the large one. My manual machine (6x26 knee mill) does have a DRO.
    May 2010
    So I was looking at throwing a set of the DigiKey Encoders on, which have a variety of hole mounts. I am looking at a Taig since I am currently attending college as a mechanical engineer and there is no machine shop, which I consider ridiculous, but I don't think there is the impetus to get fullsize machines at the moment. I am unfortunately a ridiculous distance from my rescued Hurco KM3, and miss having such tools available to me.
    I can't really put the time into a CNC conversion right now, and I'm not thrilled with the prices that Taig has for full CNC'd mills out of the box, I think I can do much better for much less, especially since I have the experience of converting my KM3 already under my belt, I just need a month or two that I can work on it seriously, and I don't have that time.
    Banned
    Jul 2009
    us
    A closed loop system is good for servos (required, actually), but not so good with steppers. A Taig-sized machine is best suited to steppers. I would avoid attempting to set up a closed loop system on one. The only commercial closed-loop system for them that I know of is godawful and completely pointless.
    As for manual DRO's, the Chinese slides use a bizarre coding system that is simple, but entirely their own. I do recall the someone made a simple converter that plugged into them and output standard quadrature, however. Sure a search will turn it up.
    May 2010
    Would standard quadrature encoders be an acceptable way of doing a manual DRO? It would be cheaper than linear slides and seems like it should be as accurate, especially since I would get as much accuracy as using stepper driven axes.
    Banned
    Jul 2009
    us
    You asked about backlash, and on the Taig you should get about .0015 or so on X and Y, zero on Z of course, on a totally stock mill. There are very easy (and cheap) mods to get that to a true zero backlash on all axes if it is required, but it is often not necessary to completely eliminate it for most purposes. Trying to use rotary shaft encoders would be one of those times, however!
    May 2010
    Okay, so in your opinion what is my best approach?
    Jan 2007
    Uinted Kingdom
    Quote Originally Posted by cameraguy View Post
    The simple answer here is that one has to manage the physical backlash properly and keep things as 'tight' as you can. The latency in getting a position from a Chinese scale means that it is no use for controlling the actual position, only confirming a position once movement has ceased. Even the quadrature scale inputs into Mach3 can only be used to confirm position and produces an error if a final position is not reached.
    'Closed loop' will only work by directly driving the motor and controlling the MOTOR position and since the Taig backlash is after the motor, even switching to servo's will not do anything for that. Putting the feedback sensor on the bed rather than the motor shaft will just create an unstable mess on this type of closed loop controller.
    Mach3's backlash compensation works reasonably well as long as the backlash is being managed well by regular maintenance.
    As for CNC versions of the Taig mill ... Buy the CNC ready basic mill and three stepper motor mounts, and then the only 'conversion' work is to add your own stepper motors and drivers. The cost of scales would go some way to buying the CNC kit instead?
    Lester Caine - G8HFL
    http://medw.co.uk - Home of electronics for the Model Engineer
    hub
    hub is offline
    Sep 2010
    Finland
    Depends on where you would mount the encoders. If on the leadscrew your reading would be a reference to the leadscrew revs. It there is backlash between leadscrew & nut, the DRO reading would be off (by backlash amount), at least in one direction.
    But that might not be a problem, you could always calculate off the backlash amount in one direction..
    Hub
    May 2010
    Iisces, I understand this, I just don't see A) where my benefit is driving the axes with steppers off the leadscrews over counting rotations on the leadscrews, unless there is no backlash compensation in the shumatech, and B) I really would prefer to be able to do a DRO with by-hand machining, and AFAIK, you cannot use back driven stepper motors for this. I've been trying to get information on the improvements ill get for purchasing a computer ready model, since you are advocating one, I'm all ears. from what I can tell all I get are motor mounts and a bigger motor, both of which I can purchase seperately.
    Banned
    Jul 2009
    us
    Bigger motor, motor mounts, and better leadscrew nuts that allow backlash adjustment. All of which can indeed be purchased separately.
    If you want to go manual, I would just purchase the CR kit and a set of handcranks, and put the stepper mounts on the shelf until later. The motor upgrade and the split nuts are nice to have even just using it in manual mode.
  • Page 1 of 3 123 LastLast
    1. Spiral anti-backlash couplers introducing backlash!
      By MArruda in forum DIY CNC Router Table Machines
      Last Post: 06-07-2011, 03:31 AM
    2. Backlash Compensation / Backlash
      By dwessels in forum Benchtop Machines
      Last Post: 02-23-2009, 11:27 AM
    3. Replies: 8
      Last Post: 03-10-2008, 04:35 PM
    4. Servo idea - elimated backlash - zero backlash !
      By synthetiklone in forum Linear and Rotary Motion
      Last Post: 12-06-2006, 02:35 PM
    5. backlash
      By fred klusmann in forum General Metalwork Discussion
      Last Post: 10-04-2006, 12:19 PM
