Here is the procedure I use for adjusting the Taig CNC leadscrews:
Taig Mill Setup
I actually found that most of my backlash was due to the coupler between the stepper motors and the leadscrew. I tried to minimize the gap where you can see the plastic tubes in the middle of the coupler, also, making sure the nut tightening the coupler to the leadscrew is not too tight or too lose.
regarding the play you feel in the spindle, this doesn't sound right. maybe that's something you need to bring up with Taig or wait until someone with more experience chimes in.
In 6061, i have pretty good luck running 15-20 IPM, at .02" DOC with a 1/4", 2-flute endmill, but I can't recall which pulley, maybe the 2nd or 3rd from the fastest spindle speed. I'm sure I can go faster, but I have not increased my DOC because this chipload feels and sounds good to me. Typically, with these smaller machines high feedrates and smaller DOCs are needed due to the relative lack of rigidity.
-steve
LinkBack URL
About LinkBacks
