Results 1 to 5 of 5
Thread: taig mill as plotter?
    Feb 2009
    Maybe this is a dumb question, but can this be done? I was wanting to cut some holographic tape.
    David L. Aery
    www.hooksolutions.com
    Apr 2004
    Oakland CA USA
    I don't see why not
    as long as your tape fits comfortably in the work envelope. All you'd need is a fixture to hold the tape down securely to a spoilboard, and a drag-knife that fits in the spindle. Here's one that would probably work:
    Sign Vinyl Drag Knife Bit - Use Your CNC Machine to Cut Vinyl Stickers and Lettering, Paper, Cardboard, and Plastic - WidgetWorks Unlimited
    You'll probably have to design and build the fixture yourself, though. The site above has some pressure feet that you might be able to adapt, but a vacuum pod would probably help as well.
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
    Feb 2009
    Thanks Andrew! That is just what I was looking for. I am ordering one now.
    Thanks again.
    David L. Aery
    May 2007
    Quote Originally Posted by dlaery View Post
    Thanks again.
    While a Taig mill can be used if you already have it, but if you need to buy one would it not be better to look at something designed for the work you want to do?
    The Taig mill has limited travels, table size and is very slow compaired to a router/plotter.
    Feb 2009
    Quote Originally Posted by Andre' B View Post
    Hey thanks, Yes I would agree but, I checked and I needed to cut holographic tape and minimum recommendation plotter for that was going to start at $1500.
    I just didn't want to invest that much at the trial and error stage. This tool/cutter with a couple extra tips is costing $185.
    David L. Aery
    1. Replies: 0
      Last Post: 06-02-2010, 05:26 AM
    2. De Plotter de Plumas A3 a Plotter de corte y laser...
      By GTIHZ in forum Spanish CNCzone
      Last Post: 03-20-2010, 12:37 AM
    3. Where to find Shell mill / Face mill arbor for taig
      By 725franky in forum Taig Mills & Lathes
      Last Post: 11-18-2009, 05:48 PM
    4. Coming Down to the Taig Micro Mill or Grizzly Mini Mill.
      By SpeedsCustom in forum Taig Mills & Lathes
      Last Post: 01-23-2009, 12:14 AM
    5. Taig 3 Jaw Chuck on Taig Mill?
      By jim_stoll in forum Taig Mills & Lathes
      Last Post: 09-14-2007, 06:44 PM
