Results 1 to 9 of 9
Thread: Favourite facing cutters for Taig mill?
    Jan 2011
    Question Favourite facing cutters for Taig mill?
    I am mostly using 1/8" end mills to cut aluminum, it generally gives me the right balance of detail and power for what I am making - the one area where they are really sub-optimal is when I am facing larger blocks (4" x 6" for example) prior to milling out e.g. a mould, then it takes forever to cover the whole surface, especially if I set some overlap. What would you recommend as the "best" (in terms of both surface flatness and stock removal rate) facing cutter for aluminum in a DSLS3000 CNC Taig mill?
    thanks!
    Mark
    Registered Jeff-Birt's Avatar
    Feb 2007
    It is hard to beat a fly cutter for surfacing a large area. Taig has one available with a 3/8" shank for the mill that works well.
    Jeff Birt
    Jul 2007
    Probably the best bet for surfacing is a fly cutter. It leaves a nice surface but you can't take very deep cuts. I think it is about $30. Other than that, I use a 3/8" end mill.
    bob
    Feb 2010
    I got the flycutter recently, do i need to shape the cutter before using it or is it fine out of the box?
    Feb 2007
    I fyou have the one that Taig sells it comes with a pregorund bit that is ready to go out of the box. Just make sure you put the bit in the correct direction.
    Jeff Birt
    Feb 2010
    I tried flycutting some 6061 alu this past week teaching myself how to square a cube, and the finish came out very fuzzy. Is there a way to get the smooth glass finish like i see on youtube videos? I read on another forum that this happens when the tip of the cutter is a sharp point and that rounding it off will improve the finish. Is that true? I was running with the third pulley from the bottom and hand jogging in mach across the material at .01 steps on the z each pass i believe.
    Feb 2009
    Through a search I found how to shape up the end of the fly cutter to make a mirror finish. I use the 2nd pully from the bottom and only take .005 per pass.
    David L. Aery
    www.hooksolutions.com
    Apr 2010
    U.S.A
    Quote Originally Posted by dlaery View Post
    Do you happen to have the link handy?
    Feb 2009
    Sorry, I didn't save any links and I have slept since then.
    Here is what I think I used (picture)
    fly cutter
    I did a search on Google: shape fly cutter
    Hope this helps.
    David L. Aery
    1. How to choose a Facing Mill or Fly Cutter
      By TimGS in forum Vertical Mill, Lathe Project Log
      Last Post: 11-30-2009, 10:23 PM
    2. Where to find Shell mill / Face mill arbor for taig
      By 725franky in forum Taig Mills & Lathes
      Last Post: 11-18-2009, 05:48 PM
    3. LETTERING HARDWOOD CUTTERS? AND PLYWOOD CUTTERS
      By andycorleone in forum WoodWorking
      Last Post: 12-12-2008, 01:36 PM
    4. Taig 3 Jaw Chuck on Taig Mill?
      By jim_stoll in forum Taig Mills & Lathes
      Last Post: 09-14-2007, 06:44 PM
    5. Collet type & Alu mill cutters
      By fotiosanagnosto in forum General Metalwork Discussion
      Last Post: 05-19-2007, 02:45 PM
