Results 1 to 10 of 10
Thread: How thick polycarbonate for enclosure?
    Jan 2011
    Question How thick polycarbonate for enclosure?
    I am making an enclosure for my CNC Taig mill, mostly to contain the mess and to keep passers-by from sticking their heads too close to see what it's doing. I think 48" wide by 36" deep by 30" high should do the trick (and fit the bench nicely). I am thinking of using polycarbonate, but am not sure how thick to make it, as cost is an issue. Do you think 3 mm would work? Or is that too thin to be comfortably self-supporting?
    Mark
    Jul 2005
    3mm should be sufficient to keep swarf and coolant in.
    I've been looking into using 80/20 Quick Frame for an enclosure, and I know many people have had good luck with it. The standard thickness that 80/20 offers ranges from 4.5mm to 6mm, however this doesn't mean this range is what your requirement needs. Personally, I plan on building with 4.5mm thick panels for increased rigidity, but obviously I'll probably end up paying more in material.
    Jul 2007
    I used Coroplast (HD carries it or beg some from a sign shop) to make the walls of my enclosure. If you don't need the whole enclosure to be transparent, it is a good option for a small mill. Since I don't use coolant 16-20" was high enough.
    bob
    Jan 2011
    Quote Originally Posted by 900steve View Post
    I was thinking of doing it frameless, solvent welding and then using this stuff for hinges - do you think that would work?
    Jul 2005
    you should try solvent welding first on a sample to make sure your hinge and enclosure materials will be compatible.
    I think you may want to have some gussets to reinforce the joints where you have welds, but it sounds like it can be done.
    Jan 2011
    OK, thanks
    The quick-frame is a neat idea, I hadn't seen that stuff before - I am having trouble finding pricing info on the 80/20 web site though - do you know where it is?
    Mark
    Jul 2005
    you have to go through a distributor for 80/20 pricing, or probably contact them directly. but check on eBay, 80/20 has a "garage sale" store there where you can get good deals if you wait and watch for what you need.
    Oct 2006
    Hey Mark,
    I just finished my second tank and I'm around $350 but a lot of the cost comes from 75% of this build being a Home Depot build.., so what size Taig do you have?
    Oct 2006
    Here is a pic.. I'm at 3' 2" long / 2'5" high / 19 deep my motor pops out of the top Z fully extended.. but I also have her on (about) 2 " stilts
    Attached Thumbnails Attached Thumbnails How thick polycarbonate for enclosure?-img_0507%5B1%5D.jpg
    Apr 2010
    Quote Originally Posted by MarkU View Post
    Mark
    I built an enclosure for my Sherline which is slightly smaller, and built it from 1/8" generic plexiglass. 1/8" is pretty close to 3mm.
    I used short bits of al angle with screws to attach the plex to the base, and attach the corners.
    The 1/8" enclosure is a lot stiffer than I thought it was going to be.
    Tom
    1. Machining Polycarbonate
      By jdwhittaker in forum Glass, Plastic and Stone
      Last Post: 03-15-2013, 05:25 AM
    2. (855) POLYCARBONATE CLEAR 3/8"THICK 24"X 48"
      By CNCadmin in forum EBAY ADS
      Last Post: 04-18-2011, 02:20 PM
    3. Newbie- Cutting polycarbonate
      By BuckeyenNJ in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 01-22-2011, 04:33 PM
    4. Polycarbonate forming
      By thorsgaard in forum Vacuum forming, Thermoforming Etc
      Last Post: 09-21-2007, 06:22 PM
    5. Hardened Polycarbonate
      By pointless in forum General Material Machining Solutions
      Last Post: 07-17-2007, 10:00 PM
