Results 1 to 5 of 5
Thread: First Time Cutting Tool Steel
    Nov 2009
    I'm reducing a section of 1/2" drill rod 2.4" long to 3/8" for a tee slot cutter. The stock is mounted in the chuck on rotary table and supported by tailstock.
    First time I've cut drill rod and can't get a feed and speed that does not vibrate!I've tried (with a 1/4" HSS cutter):
    - Cutting from above, using bottom of cutter, rotating 360 then shifting sideways
    - As above but going end to end then 10 degree shifts (for roughing)
    - Going end to end using side of cutter (Y axis to set depth of cut).
    Calculated values at 1100 rpm of 6 in/min with a 0.01 cut.
    Best results I can get are a 0.003" cut at 15 in/min and 1100 rpm but surface is still rough and light vibration while cutting. I tried other speeds and any deeper cuts just make it worse. Cutting using the side of the mill seems best but I'd really appreciate some advice from others who may have tried this.
    Registered neilw20's Avatar
    Jun 2007
    A carbide cutter will work much better.
    Have you thought of mounting the drill rod in the spindle, and mounting a tool in a vice and using the mill for a lathe?
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Nov 2009
    Thanks. I'll get a carbide cutter on weekend. Did consider vertical lathe but no way to hold 1/2" stock.
    Nov 2009
    Carbide cutter definetly helped. Still some minor chatter so am experimenting with feed rate. Much better than before. Thanks.
    Registered BobWarfield's Avatar
    May 2005
    John, are you able to see the chatter marks on the workpiece?
    If you can see them well enough to measure the distance between them, you can use the chatter pitch calculator in G-Wizard to figure the optimal spindle speed to minimize the chatter.
    Best,
    Bob Warfield
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
    1. First Time Milling Steel - Snapped a cutter - HELP!
      By UKRobotics in forum General Metalwork Discussion
      Last Post: 04-29-2010, 05:55 PM
    2. Question on shortening cutting time
      By keithmcelhinney in forum Novakon Systems
      Last Post: 03-03-2010, 02:30 PM
    3. cutting aluminum for the frist time with cnc
      By eloid in forum DIY CNC Router Table Machines
      Last Post: 07-21-2009, 08:22 PM
    4. Need Help!- Machine (cutting time) V22
      By jensen in forum BobCad-Cam
      Last Post: 02-18-2009, 05:09 PM
    5. Weee! first time machining Stainless Steel
      By ImanCarrot in forum General Metalwork Discussion
      Last Post: 02-08-2008, 02:25 PM
