Results 1 to 4 of 4
Thread: Dowel in center of table
    Oct 2010
    I'm looking to add some plastic gutters around the table to drain off coolant away from the screw, gibs, etc. Would I be able to trim that dowel that sits about the x axis lock screw down to about half it's current height without hurting it?
    Aug 2008
    From discussion on the yahoo taig group: That dowel is to set your X-axis stop points, maybe not needed as much with cnc but you could use it for your limit switches. (see Nick's Taig Lathe and Milling Machine Blog: X Axis Travel Stops for the Taig Milling Machine)
    I read another thread somewhere where people said that they milled it down, can't see how it would be detrimental.
    Regards
    Verm
    Registered Twmaster's Avatar
    Aug 2004
    USA!
    You won't hurt anything by removing that dowel. I've never used it as a stop in the 2 years I've had my mill. Of course YMMV...
    Mike N
    No good deed goes unpunished.
    Oct 2010
    I cut it in half and tossed some covers around the edge of the table now. Helps keep most of the liquid and chips out.
  1. Table Slot Center -to Center distance
    By bostosh in forum Haas Mills
    Last Post: 10-25-2010, 10:41 AM
  2. Bring table to center
    By bowmaster in forum Haas Mills
    Last Post: 07-25-2010, 11:17 PM
  3. Need Help!- Best way to center rotary table
    By Micro Milling in forum General Metal Working Machines
    Last Post: 12-30-2009, 09:50 PM
  4. Need Help!- How to center a part on a rotary table
    By ryansuperbee in forum Benchtop Machines
    Last Post: 07-30-2008, 05:17 AM
  5. spindle to center of X&Y table?
    By ZipSnipe in forum General Metal Working Machines
    Last Post: 07-26-2006, 08:05 AM
