Results 1 to 3 of 3
Thread: X Reversed
    Jun 2009
    America
    X Reversed
    I've had this problem since I got the mill up and running but for what I was doing it didn't matter but now I will be moving onto other projects . + and - are reversed in the X axis, Y and Z are fine. Looks to me I wired the wires correct so is there a setting I should check?
    Apr 2004
    Oakland CA USA
    Change the Direction bit
    Look in Config/ports and pins/motor outputs. If the X axis Direction bit is set to "Low active", click that box so it changes to "high active" - or vise-versa. That should change the motor direction: Positive X should move the bed of the mill to the left (your left, as you're facing it); negative X moves are to the right.
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
    Quote Originally Posted by mishawaka View Post
    Registered Jeff-Birt's Avatar
    Feb 2007
    How are judging that X is backwards? You have to judge the direction of movement as if the spindle were moving (even if the table actually moves). For example if you jog to the right then the table will move to the left (same effect as spindle was moving right.) The same thing goes for the Y-axis on most machines. For the X axis jogging up (+) is up (away from table) and down (-) is towards table.
    Jeff Birt
  1. Z-axis reversed?
    By hjl4 in forum FeatureCAM CAD/CAM
    Last Post: 01-27-2011, 05:12 AM
  2. Newbie- Z movement is reversed
    By klaymonster in forum Mach Mill
    Last Post: 03-09-2010, 03:55 PM
  3. Need Help!- when it jogging (reversed) X= -30 cm I get X= -28 cm
    By cadnet in forum Mach Software (ArtSoft software)
    Last Post: 02-25-2010, 02:32 PM
  4. Need Help!- Plus and Minus Reversed
    By cncboss6 in forum Mach Wizards, Macros, & Addons
    Last Post: 04-06-2009, 09:31 PM
