Results 1 to 8 of 8
Thread: NEED ADVICE - WHERE TO BUY 2 AXIS CONTROLER
    Dec 2007
    canada
    Like the title says , I am building a CNC lathe and am now looking for a controler that is good and won't rape my wallet . any and all input is welcome
    The stepper motors ( Nema 23 ) I already have
    Thank you guys
    Feb 2009
    Xylotex
    When I upgraded my Sherline I used Xylotex drivers. They have only three-axis driver boxes, but I only used two of the outlets. They're reasonably priced and work great.
    Hope this helps.
    Feb 2008
    G540 is $250ish. It includes two drivers that you won't use, but I expect that the other quality options aren't that much cheaper by the time you include a breakout board.
    You might also watch for used ones. I see them float by on Craigslist from time to time. I just sold an older SuperTech controller ready to go (power supply, relay board, 3 axis) to a local person for $75. It was not as good as a G540 and only did half-stepping instead of micro-stepping, but it was reliable. Those deals are out there.
    Won't a 3rd axis eventually be useful for the tailstock? Or do most smaller CNC lathes not have a powered tailstock and use the toolholder for holding drills?
    Dec 2007
    canada
    The G540 sounds like a great deal I still need a power supply with that correct.....?? , I am sure I will find a use for the 3rd axis eventualy
    Feb 2008
    Yes, turning the G540 into a minimally functional system also requires a power supply, power input, and an enclosure.
    I'm using the 48V power supply that Keling sells.
    Dec 2007
    canada
    Whats the difference between a power supply and power input
    thank you for the input BTW
    Feb 2008
    Power input module has the IEC connector for the power cord, a power switch, and a fuse. You can have 1 to three separate items for this. You could just have a power cord going straight to the power supply, but I wouldn't recommend it unless your power supply has a power switch and fuse integrated.
    alex
    Dec 2007
    canada
    Oh I just thought something went inbetween the power supply and the G540 , Something I missed.......its all good
    1. DYI 4th axis advice?
      By Spinnetti in forum General Metal Working Machines
      Last Post: 01-17-2011, 11:47 AM
    2. GMR cnc 5 axis w/ Fagor controler info?
      By Jim Brown in forum CNCzone Club House
      Last Post: 12-20-2009, 08:12 AM
    3. Problem- DIY controler X-axis issue
      By KsiR in forum Stepper Motors and Drives
      Last Post: 02-19-2008, 09:56 PM
    4. Z axis need advice
      By Kev in forum DIY CNC Router Table Machines
      Last Post: 07-19-2007, 08:11 PM
    5. camsoft and yaskawa axis controler
      By hugo cuvilliez in forum CamSoft Products
      Last Post: 05-25-2006, 06:02 PM
