Results 1 to 3 of 3
Thread: Tips for achieving accuracy
    Oct 2010
    Had a few questions in regards to getting the most accuracy out of the Taig that I was hoping someone could answer.
    I followed the leadscrew adjustment procedure off Carter's website and got my X/Y backlash down to .001" or less for both axis. However, I couldn't find any information on adjusting the Z axis.
    With backlash of .001" or under should I even turn on backlash comp in Mach3 for these axis?
    Is measuring a slot cut for a mill end an acceptable way to determine its actual diameter?
    Registered Jeff-Birt's Avatar
    Feb 2007
    The Z-axis has the same type of split nut to adjust for backlash. You also have to adjust the side 'clamps' on it after several hours of initial use. Getting to the Z-axis nut is not very hard, unscrew the two bolts that hold the bearing block to the Z-column and slide it up. the 'clamps' I'm talking about are the "l" shaped pieces on each side of the Z-axis truck. After several hours of initial use you notice the z-axis is a little sloppy, loosen two screws on one of these clamps, squeeze it as hard as you can with your hand to squeeze the Z-ways between the Z-axis truck and clamp and tighten the screws, do the same for the other side.
    Cutting a slot is not a very accurate way to determine tool size, no matter what the tool will wander a bit do to run-out, banging on already cut chips etc.
    Jeff Birt
    Registered speedtwin69's Avatar
    Oct 2009
    If you really want to check it close bore a 1" hole or whatever and use a bore mic. That's how I tuned mine in to less than a .001 or mill a 1.00 square.
  1. SL30 Achieving Tolerances and Warm Up
    By dlall in forum Haas Lathes
    Last Post: 03-05-2010, 08:33 AM
  2. achieving 5 axie
    By xclr82xtc in forum General Metal Working Machines
    Last Post: 07-04-2009, 10:25 AM
  3. Achieving positional accuracy on subplate holes?
    By Donkey Hotey in forum General Metalwork Discussion
    Last Post: 12-22-2008, 12:56 PM
  4. Replies: 0
    Last Post: 09-29-2006, 02:17 PM
  5. Drafts: Tips for vendors and tips for RFQ writers...
    By InspirationTool in forum Employment Opportunity
    Last Post: 12-20-2005, 09:44 PM
