Results 1 to 9 of 9
Thread: vfd question
    Jul 2008
    vfd question
    has anyone added a variable frequency drive to thier taig? and if so which one and how much was it?
    i really want to be able to use m-code to start and stop my spindle...
    is rapid tapping an option when using a vfd?
    Registered Jeff-Birt's Avatar
    Feb 2007
    You don't need a VFD to start and stop your spindle through M code, just a relay. Also, you must add the VFD (speed controller) and a new motor to have variable speed. I just built up a system for someone like this.
    If you add an index (tach) sensor to the spindle and supply that back to Mach it can sync axis movements to the spindle to do single point threading.
    Jeff Birt
    Registered M250cnc's Avatar
    Sep 2007
    England
    You would need a servo motor for Rigid tapping and it's not currently supported in Mach but yes in EMC 2
    Phil
    Sent from my HTC Desire using Tapatalk
    Jul 2008
    Quote Originally Posted by M250cnc View Post
    Phil
    i do have a copy of emc 2 but i have not really played with it
    Quote Originally Posted by Jeff-Birt View Post
    do you have a part list i could see jeff?
    Apr 2004
    Oakland CA USA
    Taig has a relay box that works
    to turn your spindle (and one other 110v appliance, like a dust collector or coolant pump) on and off with M-codes. They call it the "spindle and auxilliary control module, and it's listed on the Microproto site for $100: MicroMill 2000
    I don't know of anyone who has gotten rigid tapping to work on a Taig, but I guess it's not impossible. Thread milling would be a lot easier, though, with the right software.
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
    Registered fretsman's Avatar
    Nov 2007
    You could actually build your own relay box with this very well done tutorial:
    Tom Benedict Builds a Relay Box for His Taig CNC Mill
    Dave
    Dave->..
  7. #7
    Jul 2008
    Quote Originally Posted by fretsman View Post
    Dave
    that is a great tutorial....
    i was thinking along those lines
    i have 2 relays left over from another job
    only problem is that they are 24v dc triggers and 300v 10a through voltage.
    im pretty sure that the power supply is putting out 48v ...but im not sure whats coming out of the gekco 540.
    page 6 on the 540 manual shoes a relay power supply but gives no voltage
    page 3 says the analog output to the vfd is 10v (it does not say if its ac or dc) and gives no info on the output for the relays
    any thoughts or suggestions?
  8. #8
    Feb 2007
    The relay outputs on the G540 do not output a voltage, they switch to DC Common. You wire the relay coil between the +V of your power supply and the G540 output. The G540 output switches to DC Common and the relay is energized. You can use any voltage relay as long as you have a matching power supply for them and wire the DC Common of the G540 power supply and the relay power suppl together.
    Jeff Birt
  9. #9
    Jul 2008
    ok im going to have to read that a few times! i get the concept...but where the actual leads go...hum? on my relay (rh4b-u) pin 13 is labeled negative and pin 14 positive. im confused do i hook the relay power supply +vdc to the - negative on the trigger for the relay? or is it the other way around?
    i guess to sum it up im looking at page 6 of the 540 manual what lead on the relay (+ or -) is hooked to the +vdc?
    thanks again jeff
