Results 1 to 8 of 8
Thread: 1/4hp taig mill won't spin up on fast pulley
    Sep 2010
    Nanaimo
    I finally found myself in a place with room for a workshop. Got my taig mil (the CR model with the 1/4 hp motor) out of storage and put an ER16 spindle on it. I've done a bunch of cutting with it, and mostly everything works great.
    The problem is when I put it on either of the two fastest pulleys. It turns maybe 200 rpm, and won't ever get up to speed. Doesn't matter how loose or tight the belt is.
    Doing the reversed ohmmeter test on the start cap suggests that it's OK. I'm not sure what else to try.
    Registered Jeff-Birt's Avatar
    Feb 2007
    Well, if the motor comes up to speed without the belt on it points towards the spindle itself. If it is a new spindle then you may want to run it for a few hours to break the bearings in and see how it does at higher speeds.
    Jeff Birt
    Sep 2010
    Nanaimo
    Broken in... or just broken?
    Thanks, that seems to have worked. Ran it for a half-hour on the third-fastest pulley, then it would spin up (barely) on the second. Ten minutes of that, and it worked on the fastest.
    The spindle itself seems mighty hot after that (uncomfortably hot to the touch) but I'm hoping that's just because it's still breaking in.
    Feb 2007
    I cut parts all weekend at 10,000 RPM (top speeds) and the spindle just got warm to the touch. If it is getting really hot it could be the belt slipping or a bad bearing (or two).
    Was this a new spindle?
    Jeff Birt
    Sep 2010
    Nanaimo
    Yes, brand new spindle from A2Z. I'll check with them.
    Sep 2010
    Nanaimo
    Update:
    I got a very helpful explanation from Tim at A2Z. He says that the overheating behaviour I'm observing is due to pre-load on the bearings, and is to be expected while they seat in. Basically I just need to be careful at high speeds for a while, and shut it down for a cooldown period when things get too hot. He said it took 40 hours on his taig.
    The hard starting is likely because I have the older single-capacitor taig motor, which doesn't have great starting torque. It should go away as the bearings seat in.
    Registered M250cnc's Avatar
    Sep 2007
    England
    Sep 2010
    Nanaimo
    1. too fast for pulley issue
      By 15mgtar in forum Machines running Mach Software
      Last Post: 01-10-2012, 08:36 PM
    2. Taig belt broken, feeding too fast?
      By bangzilla in forum Benchtop Machines
      Last Post: 09-23-2010, 11:13 PM
    3. Have a huge prblem with Taig, Need help FAST!
      By SpeedsCustom in forum Taig Mills & Lathes
      Last Post: 04-17-2008, 07:10 PM
    4. How fast can you spin Acme thread?
      By Ed_R in forum Linear and Rotary Motion
      Last Post: 11-12-2006, 08:55 PM
    5. Removing pulley from Taig spindle
      By warpedmephisto in forum Taig Mills & Lathes
      Last Post: 04-02-2006, 05:53 PM
