Results 1 to 7 of 7
Thread: How to add Touch Probe
    Nov 2010
    done some searching but can't find info on how to attach a touch probe to gecko 540 from Mach 3
    found the blue screen with probe on mach site and downloaded it and thats as far as i get
    Nov 2010
    Hmmm no one using a touch off plate on their G540,,,
    Aug 2008
    I have one but using EMC2 not Mach3 so I am not much help to you. I am assuming you have already done so but if you need to wire it up you can get some diagrams from Geckodrive. Surely somebody will be able to help you.
    All the best
    Verm
    Jul 2007
    I would have to take my control box apart to be absolutely sure but as I remember it was trivial. I installed a pair of banana jacks in the front panel of my control box, one is connected to an input on the G540 which is appropriately mapped in Mach and the other is connected to the G540 ground.
    Have you seen this thread? XYZ Probe modification
    bob
    Nov 2010
    after reading some posts here, looks like input 13 on the 540 and then a ground
    just have to find the right script now
    Registered fretsman's Avatar
    Nov 2007
    This the script I've been using for Mach3 from here at the Zone:
    This is inches and you can set some of the variables as you would like them to be set.
    As always, take care when using scripts as you must use these at your own risk.
    Dave
    CurrentFeed = GetOemDRO(818) 'Get the current feedrate to return to later
    CurrentAbsInc = GetOemLED(48) 'Get the current G90/G91 state
    CurrentGmode = GetOemDRO(819) 'Get the current G0/G1 state
    PlateThickness = GetUserDRO(1151) 'Z-plate thickness DRO
    If GetOemLed (825)=0 Then 'Check to see if the probe is already grounded or faulty
    DoOEMButton (1010) 'zero the Z axis so the probe move will start from here
    Code "G4 P2" ' this delay gives me time to get from computer to hold probe in place
    Code "G90 G31Z-20 F10" 'probing move, can set the feed rate here as well as how far to move
    While IsMoving() 'wait while it happens
    Wend
    ZProbePos = GetVar(2002) 'get the axact point the probe was hit
    Code "G0 Z" &ZProbePos 'go back to that point, always a very small amount of overrun
    While IsMoving ()
    Wend
    Call SetDro (2, PlateThickness) 'set the Z axis DRO to whatever is set as plate thickness
    Code "G4 P0.25" 'Pause for Dro to update.
    Code "G1 Z.250 F60" 'put the Z retract height you want here
    While IsMoving ()
    Wend
    Code "(Z axis is now zeroed)" 'puts this message in the status bar
    Code "F" &CurrentFeed 'Returns to prior feed rate
    Else
    Code "(Z-Plate is grounded, check connection and try again)" 'this goes in the status bar if aplicable
    End If
    If CurrentAbsInc = 0 Then 'if G91 was in effect before then return to it
    Code "G91"
    End If
    If CurrentGMode = 0 Then 'if G0 was in effect before then return to it
    Code "G0"
    End If
    Exit Sub
    Dave->..
    Nov 2010
    will give it a try
    1. cnc touch probe
      By shawnc515 in forum General Metal Working Machines
      Last Post: 09-30-2010, 06:10 PM
    2. touch probe
      By basswakr in forum General Electronics Discussion
      Last Post: 08-14-2010, 09:18 AM
    3. Touch Probe
      By Babba in forum Syil Products
      Last Post: 10-11-2009, 01:17 PM
    4. Touch probe to ir receiver??
      By REVCAM_Bob in forum General Electronics Discussion
      Last Post: 04-27-2007, 09:43 PM
    5. Touch Probe for a Noob.
      By lilricky2 in forum Digitizing and Laser Digitizing
      Last Post: 02-02-2006, 05:04 PM
