Results 1 to 3 of 3
Thread: Taig a good idea for this project?
    Oct 2010
    Looking at getting a mill and trying to decide how to spend $1800-2000. Either a larger manual setup or smaller cnc like the DG1 build or similar. The first project is pretty basic but wanted opinions on how well the Taig setup would do.
    The pictures show a piece of 6061 that is 5"x4" and 1.25" deep. The front has a total cutout depth of 25mm and the back fins are about 4.25mm deep. Can I expect repeatable accuracy down to .01mm? How long could one expect the Taig setup to make a piece like this?
    Jul 2007
    That is a nice looking part but I think your specs are too ambitious. .01mm is taxing for most big VMCs never mind an 85 lb benchtop mill. A 10 degree C shift in temperature will expand your material more than that.
    That said, a Taig can certainly do a good job on a part like that though it will take a while to do that pocket. Using a .25 in cutter figure about 20-25 ipm at between .05 and .1 inches DOC.
    Also your corners are square. That can't be done with a mill. You will have to radius your corners. Avoid too tight a radius since that will force you to use a very small end mill for a finishing pass. You would have a hard time finding a small diameter end mill that will cut that deep. This isn't Taig specific btw. A part with those square internal edges would normally be cast or forged.
    Good luck and keep us posted on your progress.
    bob
    Oct 2010
    Thanks for the input
    The part will have radius corners on it but I'm still learning autocad, especially the 3d portion of it. Haven't quite figured out how to make nice representable models in it yet. I'm more aligned with 3d Studio Max and other actual modeling applications.
    Now that I know it'll do a decent job I can go ahead and make a purchase. I can also work with the dimensions to make it more reasonable for this machine.
  1. Need Help!- MC-5VA ...???Need good idea!!!
    By Nick. in forum Okuma
    Last Post: 09-16-2009, 07:11 PM
  2. PIC Project Idea for CNC
    By RogerN in forum PIC Programing / Design
    Last Post: 11-23-2006, 05:19 PM
  3. Is it a good idea to?
    By SPEEDRE in forum Benchtop Machines
    Last Post: 08-22-2006, 09:49 PM
  4. Using X-Channel For Rails Good or Bad Idea?
    By meat in forum DIY CNC Router Table Machines
    Last Post: 02-15-2006, 11:59 PM
  5. new project idea
    By newguy in forum DIY CNC Router Table Machines
    Last Post: 10-24-2004, 09:47 PM
