Results 1 to 5 of 5
Thread: Taig Lathe cutting problem/question (Video)
    Jan 2010
    I have a Taig, I've just been using it for fun, cutting different pieces and so on- now all of a sudden I can't get a smooth cut no matter what- new cutters (same as before, but sharp) different speeds, and I've researched every "chatter" and "cutter" (types, hardness, cutting angles) related video and article I could find online. Here's the Youtube video (sorry about the poor quality, but I figured eyes-on by someone who knows their stuff is the best way...) and you can see first hand what a horrible pass I'm getting.
    Any input would be greatly appreciated!
    [nomedia="http://www.youtube.com/watch?v=nRnxZgvI2a0"]YouTube - REDNIKON TAIG PROBLEM.MOV[/nomedia]
    Apr 2003
    Copper is tough to machine because it is soft and gummy. I you can use brass I find it machines much easier..
    Milk is often recommended as a cutting "oil" for copper..
    Here is a site about machining copper..
    http://www.gearloose.com/CU.html
    Also your tools don't really look ground correct for hardly any material. But I find that grinds less than optimal often work fine for me.
    Good Luck and I hope you get more and better answers.
    Jan 2010
    Thanks for the help, gmfoster! I am new to the whole lathe thing, so I dont even know how to sharpen a bit beyond common sense, but after doing what I could to copy the details in the link you sent me, I got a nice QUIET cut, 90% CLEAN, even, no chattering, and the chips came off as tiny coils. WOW what a difference! Then I tried with oil, that didnt help or make any difference, but I am shocked what a difference there is between copper and brass! Thanks so much for the help, I'm going to work on a better "hook" and sharpening my sharpening skills. Thanks again!
    Here's how I used the hook- and then by cutting with the corner of it, not the flat edge. What a difference! The surface was a nice clean even cut, like a record. (By the way, the bits I were using were factory new, and worked great for everything I've done so far- just not the copper).
    Apr 2003
    You said you tried oil, did you try milk or condensed milk.
    That seems to be the cutting "oil" for copper..
    Not joking!
    Garry
    Apr 2003
    Also a rounder nose on that bit should help out quite a bit...
    Garry
    1. Cutting lathe question
      By Mooping in forum General Metal Working Machines
      Last Post: 08-26-2010, 09:44 PM
    2. Taig Lathe DRO question
      By n_maher in forum Taig Mills & Lathes
      Last Post: 04-03-2010, 06:10 AM
    3. My Taig CNC and Coolant~Video~
      By SpeedsCustom in forum Taig Mills & Lathes
      Last Post: 01-25-2008, 05:08 PM
    4. Taig Milling Video
      By warpedmephisto in forum Taig Mills & Lathes
      Last Post: 08-04-2006, 11:07 AM
    5. Problem cutting arc with lathe.
      By mudwhump in forum G-Code Programing
      Last Post: 05-23-2004, 01:19 PM
