Results 1 to 3 of 3
Thread: Sherline mill saddle to base slides
    Apr 2009
    Has anyone found a good way to fix galled slides on a Sherline 5400 mill base to saddle slide ? mine has the black portion starting to be worn off and now the steppers don't have enough power to move the saddle, I did adjust the gibbs but it did not help. I was wondering could a person mill the surfaces and apply turcite, would it last long or even stand up at all. Or is replacing the pieces with new the way to go ?
    Jul 2006
    Roseburg, OR USA
    I had to go look at one of my mill bases to get the geometry back in my mind. Obviously you have only time and materials to lose trying the turcite. If I were you looking at replacement I would look at the A2ZCNC extended base and table. I have them and am very well pleased with the extra travel in the X and Y axis. I know that the X axis on the A2T saddle has turcite on it.
    GeneK
    Quote Originally Posted by Reax View Post
    Sep 2010
    I had the same problem. I fixed with JB weld, work like a charm now.
  1. CNC Mill with Glass Slides and Encoders
    By stipierreinc in forum General Metal Working Machines
    Last Post: 03-28-2009, 04:51 PM
  2. How do I cut my mill base/saddle?
    By cnczoner in forum Benchtop Machines
    Last Post: 10-09-2008, 06:13 AM
  3. Machining Cast Iron Mill Saddle with X2
    By Adamj12b in forum Benchtop Machines
    Last Post: 06-26-2008, 01:16 PM
  4. Wanted: Bridgeport Mill Saddle
    By Sam Wilson in forum Want To Buy...Need help!
    Last Post: 01-21-2008, 07:22 PM
  5. Mobile base for IH Mill
    By ProGunOne in forum Industrial Hobbies (Support forum)
    Last Post: 01-16-2008, 05:03 PM
