Results 1 to 5 of 5
Thread: Finishing the work
    Jun 2010
    Melbourne, Australia
    Finishing the work
    Hi
    I am milling a cylinder type object on a 3-axis mill, I have to mill it length wise one side then turn it over and do the other side
    Whats the best way to finish a curved object to get a smooth finish?
    At the moment I'm running it parallel over each side of the cylinder with a 1/16" endmill at 1/160" steps
    Apr 2004
    Oakland CA USA
    Parallel is good for the top surface
    of a cylinder, but it gets spaced out further and further as the curve approaches the vertical. If you're having a hard time getting the whole thing smooth, try splitting the finishing cuts between parallel for the top and horizontal finishing (with a rather small vertical increment) for the sides.
    Andrew Werby
    www.computersculpture.com
    Quote Originally Posted by chris123 View Post
    Hi
    Jun 2010
    It leaves tiny groove lines with parallel and horizontal finishing
    Apr 2004
    Oakland CA USA
    Is this a ball endmill?
    If not, that would explain it - you can't make a round surface with a square-ended tool. If so, is 1/16" the largest one you can use for this? The bigger the diameter of the ball is, the shallower the cuts it will make, so it will either be smoother with a bigger tool, or you could space the cuts further apart.
    Andrew Werby
    Jun 2010
    It is not a ball endmill it is square
    I recently got some 1.5mm ball end mill, I shall try it with them
    1. Need some finishing help
      By revwarguy in forum WoodWorking
      Last Post: 08-11-2009, 10:03 PM
    2. Problem- Cut 3D Finishing
      By hstinnett in forum Vectric
      Last Post: 06-20-2008, 10:41 AM
    3. Finishing
      By jrobson in forum Surfcam
      Last Post: 03-06-2008, 04:59 AM
    4. 3 Axis Finishing
      By jamesr in forum Surfcam
      Last Post: 12-21-2007, 03:42 PM
    5. MDF Finishing Question
      By The Wizard in forum DIY CNC Router Table Machines
      Last Post: 10-31-2004, 11:29 PM
