Results 1 to 10 of 10
Thread: mach3 motor tuning
    May 2010
    germany
    mach3 motor tuning
    hi,
    guess I need some help with my mach3 motor tuning settings. I have s taig with one of the old custom deepgroove1 controllers. Think it does 8 microsteps and Im running it in mm, so whatt settings do I need?
    thanks & cheers
    Apr 2004
    Oakland CA USA
    Didn't Deepgrove
    Even tell you that much?
    Quote Originally Posted by taigfraeser View Post
    hi,
    thanks & cheers
    [The math's pretty simple: the motors have 200 full steps per revolution, the screws have 20 threads per inch. So it's 200 times 20 times 8 to get the number of microsteps per inch (32000). To get the number of microsteps per mm, divide by 25.4 which gives you 1259.8425.
    Start out with fairly low velocity and accelleration settings, and adjust it until you get smooth action at the highest speed before it starts hesitating or sounding bad (use the up-down arrow keys to move the motors in the tuning dialogue.) Then derate it about 20% as a safety margin. I hope that helps - I've heard nothing but complaints about those controllers...]
    Andrew Werby
    www.computersculpture.com
    May 2010
    germany
    thanks- yep it does sound pretty simple, and what about the sherline rotary? The motor is the same,, but I guess its not 20 tpi there?
    Apr 2004
    Oakland CA USA
    As I recall
    The Sherline rotary table takes 72 turns or the crank per complete revolution; otherwise the arithmetic is the same: 200 x 8 x 72 = 115,200. Divide by 25.4 and it comes to 4,535.4331.
    Andrew Werby
    Jan 2005
    awerby
    To go from inch to metric you have to multiply (X) by 25.4, If you want mm to inch then you divide, So 32000 micro steps per inch x 25.4=812,800
    Mactec54
    Mar 2003
    Shelby Twp, MI....USA
    Andrew is correct. You want steps/mm, not mm/inch.
    Jan 2005
    ger21
    I would like to know how that works, if you have 32000 microsteps per inch & you want to change that to mm then you have to multiply by 25.4 to get mm
    Mactec54
    Mar 2003
    Say you have 50.8 microsteps per inch, how many do you have per mm?
    2
    You divide by 25.4 to get steps per mm. You multiply to get mm per inch
    You want to know how many microsteps for one mm, which is 1/25.4 of an inch.
    Jan 2005
    ger21
    Thanks,
    The way I saw it if you have 2in you have to mulitply by 25.4=50.8mm if you have 50.8mm you divide x25.4=2in
    Mactec54
    Mar 2003
    ger21
    Thanks,
    That's how you convert inches to mm and mm to inches, but that's not what he's doing.
    1. New Machine Build- Mach3 , Config, Motor Tuning problem ( FILM OF MOTOR)
      By MDF_Markazi in forum Mach Software (ArtSoft software)
      Last Post: 04-30-2009, 03:15 AM
    2. Replies: 1
      Last Post: 10-17-2007, 12:16 PM
    3. Tuning motors in Mach3
      By tybrenis in forum Mach Software (ArtSoft software)
      Last Post: 05-07-2007, 02:59 PM
    4. Motor tuning under Mach3
      By BAustin in forum Industrial Hobbies (Support forum)
      Last Post: 12-24-2006, 12:23 AM
    5. Mach3 motor tuning question
      By kn6398 in forum Machines running Mach Software
      Last Post: 04-04-2006, 11:07 PM
