Results 1 to 6 of 6
Thread: what are your motor tuning dialog settings at?
    Apr 2010
    So my mill is up and running just fine. Now that I am learning more about the machine, I would like to know what speed you guys run your motors at. I have noticed some lengthy rapid movements... I think when I G00 I am going at 10ipm.
    Looking for that happy fast safe setting.
    Registered Jeff-Birt's Avatar
    Feb 2007
    That is like trying to compare the top speed of two cars with different engines. Your max rapid speed will depend on your motors, drivers, power supply, and the quality of the pulse stream your computer produces. For instance I can do 100 IPM with my set up but others can barely do 20 IPM. Let us know what you have for the items I mentioned above and someone might be able to give you a better idea.
    Jeff Birt
    Apr 2010
    Sorry, I forgot to post that very important peice of the puzzle!
    I am running a complete CNC DeepGroove1.com Kit.
    Gecko & 3 steppers Mach3 and I think the motors are Nema 23 double stack 280oz of holding torque 4 wire
    Feb 2007
    Is it a G540 driver or one of his old homemade ones?
    Jeff Birt
    Apr 2010
    it is a G540. I just bought the kit in the last month or so. From what I can tell the components are solid, and the price was right.
    I am wondering about the top speed for rapids, and the ramp up and down settings. Do you guys keep the Z a bit softer settings than the X and Y?
    Oct 2009
    canada
    Quote Originally Posted by surrealism View Post
    Experiment
    My rapids are all the same, I think Z acceleration is lower.
    Initially I had problems with the Z vibrating, tightening the two side clamps then adjusting the gib fixed it.
    http://www.cartertools.com/millset2.html
    1. Motor Tuning
      By john1285 in forum Mach Mill
      Last Post: 06-24-2010, 09:33 PM
    2. motor tuning settings on new vfd
      By billmiller in forum Shopmaster/Shoptask
      Last Post: 05-28-2010, 06:05 AM
    3. New Machine Build- Mach3 , Config, Motor Tuning problem ( FILM OF MOTOR)
      By MDF_Markazi in forum Mach Software (ArtSoft software)
      Last Post: 04-30-2009, 03:15 AM
    4. Motor Tuning
      By dwacker in forum DIY CNC Router Table Machines
      Last Post: 04-30-2007, 10:50 PM
    5. Oscilloscope settings for G320 servo tuning + trouble
      By giorgiocnc in forum Gecko Drives
      Last Post: 12-10-2005, 05:44 PM
