Results 1 to 9 of 9
Thread: T-Slots on the taig headstock housing
    Apr 2010
    Question T-Slots on the taig headstock housing
    These are some VERY small slots. Am I missing something here? I think I can mill the t-nut, but that's going to be a very small screw going into the spine of it.
    How do you guys utilize these? Is there a standard (or metric) nut that fits well in there? if so is there enough thread grabbing to hold?
    Fill me in guys.
    Jul 2007
    I think it takes a #4 nut and screw. It looks to be the same t-slot as on the front of the milling table and that is what Nick Carter used there when he made carriage stops: http://cartertools.blogspot.com/2010...g-milling.html
    bob
    Oct 2004
    Those t-slots use a #10 square nut. Some headstocks may have tighter t-slots as Taig was experimenting with the width in an attempt to keep the motor mounting post on the mill from slopping around too much, in that case you can file them out or use #8 screws and make your own nuts.
    Nick Carter
    Largest resource on the web about Taig lathes and mills
    www.cartertools.com
    Registered draughted's Avatar
    Sep 2007
    australia
    i thought it was a M5 thread
    Feb 2008
    Nothing in the Taig is Metric. However #10-32 and M5 are very close to each other.
    Aug 2008
    I don't want to start any trouble but I wish my Taig mill was metric. I have plenty of 10-32 Tuff nuts I have been using on my taig lathe. The smaller T-slots (like on the front of the table) I use a M3 bolt and thread a strip of brass. Imperial confuses me.
    Registered fretsman's Avatar
    Nov 2007
    Quote Originally Posted by Vermiculite View Post
    No trouble at all, I think most of us that are still in "imperial" mode would agree that we should have all gone to metric a LONG time ago.
    At least I would .. ;o)
    Dave
    Dave->..
    Apr 2010
    Quote Originally Posted by fretsman View Post
    Dave
    Dont get me started!!! Design for China manufacturing and approval from US project managers who are stuck in inch.
    Draw in Metric, so much easier. Goto school for machining and its back to standard. leave school, go back to metric, buy my mill, and have to go back to standard. FML
    Apr 2004
    Oakland CA USA
    You can use metric tee-nuts in the Taig bed slots
    I think they were #6. But mostly I use 1/4" square nuts for that. On the head, I use Sherline's tee-nuts and studs; they work perfectly.
    Andrew Werby
    www.computersculpture.com
    1. Raising Taig headstock
      By MechanoMan in forum Taig Mills & Lathes
      Last Post: 04-14-2009, 05:29 PM
    2. Taig Headstock 4th Axis Conversion
      By antiretrograde in forum Taig Mills & Lathes
      Last Post: 08-06-2008, 01:14 AM
    3. Problem- G201's in Camtronics housing
      By DCox in forum Gecko Drives
      Last Post: 03-30-2008, 10:08 PM
    4. Quick Taig headstock question:
      By fretsman in forum Taig Mills & Lathes
      Last Post: 02-08-2008, 03:42 PM
    5. Taig Headstock Improvements??
      By scubasteve_911 in forum Taig Mills & Lathes
      Last Post: 08-22-2007, 01:10 PM
