Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Taig Mills & Lathes
Taig Mills & Lathes Discuss Taig machine here.
Old 05-21-2005, 09:45 PM
Idle hands is on a distinguished road
Ball screws for Taig mills. Anyone?
I purchased a Taig cnc ready mill (2019CR) and the 3-axis servo system from IMService.
I have been learning,tweaking and tuning on this setup for almost a week now. I have made a few cuts in aluminum with my 1/8" endmill. Taking .06" deep cuts at about 30 ipm leaves a nice finish with the spindle running at 10k rpm.
Looking at the X-Y table/saddle on my Taig I see there is not much extra room for mounting ball nuts. Same goes for the Z axis.
The thought of almost no backlash for extended periods and maybe 2x the rapid speed has me thinking this would be a nice addition.
I have searched here and google and have not yet been to the yahoo group. From the ball screw/nut dimensions I have seen it looks like I would only be able to fit something in the 5-10 mm screw diameter range.
I was hoping to find some leads here. Any advice or perspectives would be much appreciated. Thank you, Chuck.
I took some short webcam videos of my setup (running dial indicators in X and Z after 'tuning'
These are zipped movie files about 2-3 megs. I was able to DL these at 3-400KBs and they only took a minute or two. It seems I needed to DL the windows media encoder to get these to work,go figure..
http://home.comcast.net/~singl3guy/encodingcnc1.rar
http://home.comcast.net/~singl3guy/X.5at100000SPS.rar
Somewhat related...
The only reason I am searching for mini ball screws instead of making parts is that one of my servo motor encoders arrived with what appeared to be shipping damage. I called IMService and they sent another complete servo assembly that day. This is unfortunate, but IMS was very easy to work with and the new servo assembly should be here any day. Other than that the system is working nicely despite my attempts to destroy something by running the system with a visibly damaged encoder. Once the damaged motor/encoder recieves a pulse/step signal it just keeps going. ESTOP ESTOP ESTOP!! Doh! thats gonna make some backlash.. Did I mention Deskcnc did a great job on their fault system?
Old 06-02-2005, 06:18 PM
DHK DHK is offline
DHK is on a distinguished road
I've also got a Taig with servos from IMService, but I used counterweighting to eliminate all backlash. Since the Taig uses large/robust feedscrews, loading the X and Y axes with 7 pounds isn't a problem. I've attached some pictures of the setup. This setup quickly clips onto the mill -- and can also be removed in a jiffy. It evenly weights the X and Y axes along the feedscrew axes. I also added a separate 5 pound weight to eliminate the offset mass of the motor on the Z axis. This allows for much smoother Z axis travel. This setup is easily repeatable to a tenth -- and I've found that the feedscrews are very linear along their travel.
-David
ID:	7980   Click image for larger version
ID:	7981   Click image for larger version
ID:	7982   Click image for larger version
ID:	7984   Click image for larger version
Old 06-02-2005, 07:41 PM
That is a nice setup. I'm sitting here trying to wrap my brain around the counter weights and the pulleys on the X-Y. The Z axis makes sense to me. It will take me some time to figure out that X-Y system though 1/10,000 repeatable sounds awesome, heck I'd have to get better calipers, my digit-cal will read 10ths..5 at a time heh.
How much travel do you estimate between tightening the preload on the nuts? I was thinking about calling Kerk motion products to see how much they wanted for some of their screws/nuts, but they probably want almost as much as ballscrews would cost. They are able to cu$tom cast some kind of low friction anti backlash nuts with low/no maintance. http://www.kerkmotion.com/products/l...lead-screw.asp
Looks like you have made some other upgrades also. Is that a 1/3 HP motor I see powering the spindle? I like the 1"? standoff on the Z axis carriage also. Are those direct drive brushless servos? If you have the 2nd gen controller I bet you can achieve some nice rapids. 60+ IPM? For some reason I'm thinking faster rapids would wear my nuts down faster, but 60 IPM would be nice I think. I am maxed out at about 40 IPM with these belt drive reducers. They take my servos 3K RPM down to about 1K.
Thank you for sharing, I think I will try something like that before looking to replace/upgrade and of my screws. After all my Taig is brand new (and I just dropped $1300.00 on A RhinoCAD/CAM bundle). I think the next upgrade will be some nice 4 amp servos maybe. Are you still using the stock torque couplings? That is something else on the short list. The fact that the mill came with 4 extra of the little plastic tubes has me expecting those to be the first to go. Nick Carter also mentioned he had upgraded his if I remember correctly.
Thanks again for sharing the nice setup. Chuck.
Old 12-26-2009, 05:55 PM
wawatobi is on a distinguished road
problems with backlash
-David
I have a Taig mill and have been having problems trying to compensate for backlash. Can you provide a source for the pulleys you are using?
R. Hood
Revolutionary Linear Drive System allanconway2 Polls 21 05-03-2009 09:27 PM
Which Ball Screws to use? Willyb Linear and Rotary Motion 4 01-19-2005 09:49 PM
Ball Screws & Nut Advice coolman General Metal Working Machines 1 12-24-2004 09:29 AM
Correct Pre-loaded on Ball Screws? Willyb General Metal Working Machines 3 12-09-2004 10:09 AM
Z-Axis and Ball Screws samualt DIY-CNC Router Table Machines 15 01-10-2004 03:10 PM
