Results 1 to 1 of 1
Thread: flood coolant and way oil
    Feb 2009
    I have a question about using way oil for lubricating the slides on my mill instead of auto trans fluid. I bought some Kool Mist #77 flood coolant and use this to keep my tool cool and chips washed away. I am mixing 10 to 12 oz per gallon water(4 oz is what is recommended). I called Kool Mist and they said it had great lubricating qualities but I don’t think they understood what I was talking about, this is washing away my lubricant (I am using auto transmission fluid for the slides.) on the slides of my mill and causing to move harder and throw the reset. The person at Kool Mist seemed to think that Kook Mist would lub my slides.
    Would way oil work better and be more water resistant? I have made channels to keep the water away from my slides which has helped. I have attached a couple pics of my channels. I got these from the lumber yard. It is some kind of plasitc channel. I got some 2 face tape from the auto parts for use on moulding on cars.
    What are some advantages of using way oil over trans oil?
    Do I need to change what I am using for flood coolant?
    Thanks,
    Attached Thumbnails Attached Thumbnails flood coolant and way oil-millchannels.jpg   flood coolant and way oil-millchannels2.jpg
    David L. Aery
    www.hooksolutions.com
  1. Flood coolant option
    By truline in forum Haas Mills
    Last Post: 05-18-2011, 07:00 PM
  2. Flood Coolant Enclosure
    By Mini Beast in forum Taig Mills & Lathes
    Last Post: 09-19-2010, 12:40 AM
  3. flood coolant
    By FUBAR62172 in forum CNCzone Club House
    Last Post: 06-05-2010, 04:32 PM
  4. NM-135 and Flood coolant
    By David Da Costa in forum Novakon Systems
    Last Post: 02-11-2010, 10:18 AM
  5. Flood coolant evaporation
    By rezcar in forum General Metalwork Discussion
    Last Post: 09-26-2009, 10:03 AM
