While it depends on the parts your making, one common way to handle a problem like this is to use the stock itself as a clamp. In other words can you place a hole between two parts that you can use to bolt through to a T-nut? Sometimes parts will already have such holes so you can set up your code to cut a few holes in the parts, then you bolt through those holes before continuing.
LinkBack URL
About LinkBacks
