Results 1 to 6 of 6
Thread: cnc lathe with C axis
    Apr 2010
    vietnam
    Do you think if there are differences between nomal cnc lath's spindle motor and C-axis cnc lathe's spindle motor?
    If there are, what is the diffrences?
    I plan to use servo motor( which is often used for X,Y,X) instead of spindle motor.What do you thick about it?
    Dec 2003
    If you use a Servo motor of sufficient size, it should be possible to achieve C axis control, on large machines, the lathe C axis was often performed by a separate C axis motor, that was disabled when the main spindle motor ran, this was to avoid the more expensive servo system on a large motor.
    I am using a Converted Fanuc AC servo motor for a small lathe C axis application.
    Last edited by Al_The_Man; 04-23-2010 at 06:41 PM. Reason: should read servo not spindle
    Apr 2010
    vietnam
    ok,thank you for your exprimence.
    So do you think what is better for C axis control between servo motor series and spindle motor series if I suppose their power(or Torque) is same?
    Dec 2003
    In a DIY situation I would prefer using a Servo motor, you get the advantage of encoder feedback to the controller, the only thing is if the motor is through gearing to the spindle, you may have to put a Z pulse detector off the final shaft for homing the C axis, or use an encoder on the final spindle if the motor to spindle coupling has backlash or gear box.
    Apr 2010
    vietnam
    Nowaday, maybe there are not very much differences between Spindle motor series and Servo motor series. I think so because I have see this Spindle motor series
    Fanuc AC spindle motor alpha series
    or Fanuc AC spindle motor beta series
    Fanuc introduces indetail C axis contour function like a optional funtion.
    Of course, we need a feedback encoder. But more specially, this spindle motor series has built-in coder
    You can review them in this:
    http://www.docstoc.com/docs/28705103...-Descriptions/
    So, I if you reviewed this, do you think built-in encoder(feedback directly from motor axis because built-in coder inside motor) is impossible to solve Belt or gear blackflash?
    Oct 2010
    pakistan
    ac induction motor as C axis
    Hi
    can anybody tell me can ac induction motor be use as C-axis , as i have to make groove , pockets and slots by using C-axis.
    regards
    arsalan
    1. 2 axis lathe
      By camtd in forum Mastercam
      Last Post: 12-19-2009, 07:05 PM
    2. Compare Catia and MCX2 for multi axis lathe/4 axis mill
      By bob1112 in forum General CAM Discussion
      Last Post: 10-10-2008, 08:15 PM
    3. New Machine Build- 4th axis and lathe
      By Ed Williams in forum Mach Software (ArtSoft software)
      Last Post: 06-05-2008, 03:27 AM
    4. 4th axis as a lathe...
      By WilliamD in forum DIY CNC Router Table Machines
      Last Post: 02-03-2006, 11:55 AM
