Page 2 of 2 FirstFirst 12
Results 13 to 19 of 19
Thread: CNC X2 -> Taig upgrade?
  1. #13
    May 2007
    Guys,
    Any chance I could have my thread back? I've only gotten 1 meaningful reply so far
  2. #14
    Registered kanton's Avatar
    Jun 2003
    sansbury,
    I am sorry I hijacked your thread. I became excited when I found out that the Taig's work envelope could be expanded so much. I thought the information would be useful to you as well.
  3. #15
    May 2007
    No worries, Kanton. I'm mostly interested though in what I could get out of a stock Taig. If I replace my X2, it's not going to be with another project.
  4. #16
    Jun 2003
    sansbury,
    I called the people at Taig twice today and discovered somethings that may be of interest to you.
    The CNC mill (3 1/2 x 15 1/2 inch table) with ER 16 Spindle has maximum travels of: X = 9.5", Y = 5.5", Z = 6.0" .
    The CNC mill (3 1/2 x 18 1/2 inch table) with ER 16 Spindle has maximum travels of: X = 12", Y = 5.5", Z = 6.0".
    They use acme screws on all axes and are not interested at this time of making longer ones although you can make a simple spacer to increase Y travel to about 6".
    I was told you could unbolt the Z axis and move it upward about 6" to increase the table to spindle distance but the Z travel would still be 6".
    Hijack over!
  • #17
    Feb 2008
    I had a manual X2, and I have a CNC'd Taig. So it isn't exactly answering your questions, but I guess it is close. I had the X2 for about 6 months before selling it, and I've had the Taig for about 6 weeks. I also own a small knee mill (Grizzly G3102).
    The Taig doesn't seem that much lighter. Rigidity is similar, in that I can make similar depth cuts in steel or aluminum with the Taig that I could with the X2. Places where the Taig saves weight (such as using an aluminum table instead of cast iron) don't really add useful rigidity to the X2.
    I adjusted the brass nuts when I first bought my (used) Taig and setup backlash compensation once under EMC2. I'd need to check my settings, but I think I have around 0.0015 backlash on X and 0.002 on Y.
    I'm using an older SuperCam controller with EMC2. I can do rapids at 30ipm, but 25ipm is safer. In aluminum I normally make 0.025" cuts using a 3/16" 2-flute bit at 7-8ipm and 6500ish rpm. These are safe numbers that work reliably for me all day long, not the maximum possible. My steppers are around 230oz/in torque. My power supply is 24 volts. My controller is halfstepping only, not microstepping.
    If you buy a used one make sure that it comes with the 1/4HP motor, or budget $100 to upgrade. I didn't pay attention to that when I was buying and quickly upgraded. The old stock 1/8HP motor stalls pretty easily.
    I'm very happy with the Taig. I use it for prototyping, not production. 90% of what I'm cutting is aluminum, but I'm glad that it can work for me with steel when I need it to.
    In direct comparison to the X2 these are the things that I like better about the Taig:
    * The gibs are easier to adjust. I really prefer tapered gibs to ones with multiple set screws.
    * Lower backlash
    * Increased Y is really helpful
    * Modular design is easy to adapt (like you can easily make a CNC lathe with a small number of parts)
    * T-slots on the head make it easy to mount accessories like a mister
    * The drive system is much quieter
    * Higher torque in lower RPMs than the X2
    I think that the only benefit for the X2 is lower cost. The Taig looks less substantial, but seems to outperform the X2 where it matters.
  • #18
    Jun 2003
    awetmore,
    You stated "* Modular design is easy to adapt (like you can easily make a CNC lathe with a small number of parts)"
    Is there a set of instructions about how to do this?
    Thanks.
  • #19
    Feb 2008
    There is at least one video on youtube.
    Put the headstock and spindle on the milling table.
    Put a Taig collet or 3-jaw chuck in the headstock.
    Buy the Taig lathe tool holder and mount it on the Z-axis.
    Use the Y to center the headstock under the lathe tool.
    Z to move the tool into the material.
    X to move the material left and right.
    This doesn't get you a tailstock or offer you any way to use one really, but it makes it possible to do simple lathe activities without buying another tool.
    alex
  • Page 2 of 2 FirstFirst 12
    1. Need to upgrade my 1/8hp Taig motor. Need suggestions.
      By antelnation in forum Taig Mills & Lathes
      Last Post: 01-02-2008, 06:50 AM
    2. DSLS upgrade for Taig
      By warpedmephisto in forum Taig Mills & Lathes
      Last Post: 12-02-2007, 03:17 PM
    3. Taig 3 Jaw Chuck on Taig Mill?
      By jim_stoll in forum Taig Mills & Lathes
      Last Post: 09-14-2007, 06:44 PM
    4. Ballscrew upgrade for Taig Mill?????
      By Philip in forum Taig Mills & Lathes
      Last Post: 12-01-2004, 11:08 AM
    5. upgrade
      By Rudee in forum Fadal
      Last Post: 01-29-2004, 10:19 AM
