Where'd you get the stepper motor from? What if you switch the x-axis motor with the z-axis?
I've had this problem from the start
Jogging the Z axis upwards always seemed a bit jittery.
I've tried many options to no avail.
I always noticed the z axis stepper motor struggle when moving/jogging/step setting the axis
I took the stepper motor off and made sure that I can turn the lead screw freely without any resistance
I adjusted the jib to what I thought would be good tension.
Put everything back and the same problem.
Finally I decided to take the spindle motor off and try moving the z axis, same problem
then I took the head stock off and tried jogging the axis up and down and the axis move smoothly, no problems at all
With the spindle motor and the headstock off the z axis move fine, however if I apply any weight to the axis, the same problem
The more weight I apply the worst it get. ( I am talking about applying little pressure with my finger can cause the stepper to make loud noise and the machine stops with an error message saying " limit switch triggered " ( I don't have limit switches )
I tried adjusting the jib in either way, no joy.
I also made sure everything is clean and well oiled
If any of you nice people can help me resolve this issue, I'll be most grateful
Thank
Are you using mach3 for the controller software? If so, I'd check the motor tuning settings in it.
The one I picked up had to be set to 40000 steps per inch, accel 4, vel 20.
http://www.deepgroove1.com/tutorials.htm
http://www.machsupport.com/videos/
So does that mean you have the "Closed Loop Servo MicroMill DSLS 3000"? Because if your motor stops and the program says you've hit a limit switch, it sounds like a servo based system...
Looks as you have hit 90 percent of the possible issues, hate to tell ya but you'll probly have to check overall concentricity of those componants, ie wheys,and there doves, the upper adjustment screws(as in your lathe's) tails, the more canted you can set it up, at a dgree that when you put the weight back on it will level itself out(parallel it ) and you mys well sit and take 3 days to ensure you are looking at it strait DONT forget to check the sevos amp load, position of the motor mount and so on and adjust as specs say cause the motor WILL burn out and there goes 1500.00 ,,,, good luck.. that type of job sucks thats why they get 180 an hour to do it,, oh yea ive got the same on an Y if you can believe it but i dont get paid that much to fix our yet,, i compensate with the amp value lol
Assuming this is a DSLS3000 ... It should work fine from the box
You say you have swapped the motors, but was that still using the same channel out of the controller for Z? If you have a four channel controller, Try using the A channel to drive the Z motor, and copy the settings from Z to A in motor tuning settings. If not, then make a note of the X and Z settings and use the X channel to drive the head.
It does sound as if perhaps you have lost a FET in the driver, although normally that does not give any smooth motion ... AH - but if the high voltage feed is not connected to the Z axis board , only the X/Y - then that may give the same effect. Check the power connections on the top board inside the controller. If Z moves fine using the X output, then there is a fault on the Z board and it will need to go back to Kurt for repair![]()
Lester Caine - G8HFL
http://medw.co.uk - Home of electronics for the Model Engineer
Yes it is the DSLS3000
I swapped the Zaxis with the Aaxis including the channels and I did get better response but still not good enough when I attach the Spindle and Headstock
I'll try few more things tomorrow, if it doesn't work I'll try sending it back for repairs
thanks for all the replies
Since Z and A share the same board, f the problem is a missing power connection, then they will give similar results. Using X instead will probably prove the point.
I am sorry guys I meant to say swapped the z and x steppers and channels
I haven't tried swapping the z and a axis , will do tomorrow and let you know what happens
thanks
You say you adjusted the gibs but have you adjusted the clamping shoes? (see midway down the second page linked)? If those are too loose or too tight, you will have grief...
http://www.cartertools.com/millset.html
http://www.cartertools.com/millset2.html
That site has a lot of good info on Taigs.
bob
Thank you guys so much for all your help and support
I finally found the problem, there must have been a loose connection inside the servo, I took apart and made sure everything was connected properly and it worked now.
after weeks of suffering with machine when I thought it was a mechanical problem, it turned out to be electrical.
Thanks once again
Sam DeHays
