Are you planning on doing production runs, or single one off jobs? For one off jobs, I wouldn't bother with gang tooling. Just get an Phase II AXA tool post and a bunch of Shars tool holders. Changing tools only take a couple of seconds, and you can set up a tool offset list in your software.
LinkBack URL
About LinkBacks
so don't know the overall length. I also thought i would have flat bottom, this would save tons of work and $ in steel. If anyone thinks this is going to be an issue or hurt rigidity i will change it to a raised/boxed bed. The material is going to be hot/cold roll steel and will be bolted together (stepper mounts, ballnut mounts will probably be alu). The x axis is so large because i will be using gang tooling. i have no plans to make a tailstock at this point because im turning mostly 1.5" aluminum that is fairly short.
