Alternatives to the original Taig spindle motor?
Page 1 of 2 12 LastLast
Results 1 to 12 of 17
Thread: Alternatives to the original Taig spindle motor?
    May 2006
    NORWAY
    Default Alternatives to the original Taig spindle motor?
    Gold Member Fastest1's Avatar
    Nov 2009
    Default Re: Alternatives to the original Taig spindle motor?
    ebay
    A lazy man does it twice.
    May 2006
    NORWAY
    Quote Originally Posted by Fastest1 View Post
    ebay
    I´ve understood that not all of the spindles that are sold on ebay are good. I need to know which of them I have to buy.
    Gold Member
    Apr 2004
    Oakland CA USA
    What did you want to cut? The Chinese spindles on Ebay generally go quite fast, which is fine for wood and plastics, but not so good for metals. They are way too fast to use as a motor on the standard Taig; the bearings aren't rated for more than 10k rpm. But the standard Taig motor won't work well on 50hz current, which you use there. I generally advise European clients to purchase a Taig without the motor, and source one locally. You'd want one with close to the same specs: totally enclosed, fan-cooled, continuous duty, 3450 rpm, and 1/4 hp or better induction motor. That shouldn't be too hard to find. But if you really want variable speed, what about something like the Sherline DC motor, which comes with a speed controller: 33050 DC Motor and Speed Control Units — Sherline Products ?
    Andrew Werby
    Website
    May 2006
    NORWAY
    Quote Originally Posted by awerby View Post
    I´m carving and engraving in wood, so I was looking for a spindle with easier speed regulation than the belt moving on Taig and with the same speed range. I have used the original Taig now in several years on 50Hz without any other problems than some sparkling noise issues.
    Gold Member
    Apr 2004
    Oakland CA USA
    People have repurposed treadmill motors to run their spindles; the trick is to find one that's light enough. If you use one of those Chinese spindles, the speed range won't be the same. They give you a top speed that's about twice as fast, but the lowest speed of that spindle will be close to the top speed with the regular motor. Go much slower, and the torque falls away to nothing, while the fan stops providing any cooling. But if your regular motor works okay for you, save that for jobs that need slow speeds, and mount a dovetail to the back of the high-speed spindle so you can swap it in easily when you need to spin fast.
    Andrew Werby
    Website
  7. #7
    Jun 2011
    I am playing with one of the BLDC sewing machine motors....but this from GlockCNC....850w
    Also I am using one of their MT3 HD Spindles.....
    Stuart
  8. #8
    Sep 2009
    Deepgroove1 has spindle motor setup. Consew makes a brushless servo motor for controller that are all over ebay. I have been using a treadmill motor with a kb controller running with the taig step pulleys. I have a consew motor sitting on the bench it has much more torque then the treadmill, but the treadmill motor has a higher rpm. Not that it is recommended but I can spin the spindle at 18000 with the treadmill motor, I usually keep below 10,000 rpm.
    tread mill motor
    consew motor
    if you need more power
    deepgroove1
  9. #9
    Jan 2017
    Quote Originally Posted by sclelectronics View Post
    Stuart
    How is that spindle working out?
  10. #10
    Jun 2011
    Quote Originally Posted by theSSshow View Post
    Loving it!!
    I am enjoying using the TTS tooling system...
    I am currently working on controlling Mach3 Motor control.
    Using a C69 control board connected to my ESS 2nd port .
    Now I am working how to get rpm index pulse circuit......
    Stuart
  11. #11
    Jul 2011
    Stuart
    I just got the same motor. How can I bypass the foot pedal? Or any idea on what size pot I would need? I can 3d print a box I think
    If I hold the foot pedal open and flip the switch the motor doesn't spin, so maybe a fail safe. So I'm thinking wiring it closed won't work right off the bat
    MaxNC15 - currently under construction
    Torchmate 2x2 with Flashcut CNC Controls
  12. #12
    Jun 2011
    I need to find the pot that came with my motor and I will measure the resistance.
    The motor does have a built-in failsafe!!
    So when the power is turned on, the pot/pedal must be in the "Off" position.
    Then the motor will "Arm " itself. So now when you adjust the pedal/pot the motor will start to turn.
    Stuart
