what microproto 2000 do i have
Results 1 to 4 of 4
Thread: what microproto 2000 do i have
    Jul 2017
    Default what microproto 2000 do i have
    Hello
    Any ID help on this microproto 2000
    thanks
    Rick
    Attached Thumbnails Attached Thumbnails what microproto 2000 do i have-img_0046-jpg
    Jan 2007
    Uinted Kingdom
    Default Re: what microproto 2000 do i have
    The single parallel port indicates this has the step and direction board fitted and the extra DIN socket on the top corner has a few extra connections to the parallel port. Pinout SDBoard 25pinDPinout - Model Engineers Digital Workshop
    It will work with Mach3 with the Mach3T2k or Mach3T2kmm config files from Mach-in-a-box Gallery - Model Engineers Digital Workshop
    Lester Caine - G8HFL
    http://medw.co.uk - Home of electronics for the Model Engineer
    Member awerby's Avatar
    Apr 2004
    Do you have the mill that goes with it, or just the control box? Are you having a problem with it?
    Jul 2017
    Quote Originally Posted by awerby View Post
    I do have the Mill as well and it is in shop getting cleaned and repaired and updated.
    I just need mach3 and a PC to run it.
    I order a few parts to update and repair a few systems. 1. new bearings for the z lead screw and 2. a updated z nut for z axis .
    I am not sure what i am doing with the CNC part!!!!
    So and comments will be welcome
    Rick in Longmont
