Taig lathe drilling capacity
Results 1 to 2 of 2
Thread: Taig lathe drilling capacity
    Mar 2013
    Default Taig lathe drilling capacity
    I'm hoping to make some wooden wind instruments that require a 1/2" bore to be drilled in hardwood end grain with a gun drill. Irrespective of the length of the bed, would it be asking to much of the power train to do this? I like the looks and price of the Taig, but I wonder if it's jist to small for me. Thanks!
    Member awerby's Avatar
    Apr 2004
    Default Re: Taig lathe drilling capacity
    That doesn't sound impossible for the Taig lathe, if you don't have to drill too deeply. But you have to realize that the length of the bore will be limited, since the drill has to mount on the bed, not in a conventionally-mounted tailstock. So if you need to drill more than 3 inches deep or so and you want to use a miniature lathe, you might look at a Sherline instead, since they are set up more like a normal lathe.
