Taig CNC vs Tormach 440
Results 1 to 3 of 3
Thread: Taig CNC vs Tormach 440
    Dec 2014
    Default Taig CNC vs Tormach 440
    How do the Taig and the 440 Tormach stack up against each other as far as material removal? I kind of visualize both of them being truly hobby machines? Opinions please.
    Gold Member
    Jul 2007
    Default Re: Taig CNC vs Tormach 440
    The Tormach will remove much more material than a Taig. It is a bigger, heavier and more rigid machine weighing in at about 450 lbs vs the Taig's 80 ish. There is nothing wrong with a Taig but the Tormach is a step above.
    If you can afford it, the Tormach 440 would take you a lot further. But if budget is a concern, you could start a Taig then update to something bigger later. Taigs tend to hold their value pretty well so if you sell it a year or two later for only $200-$300 less than you paid for it, it effectively cost you $25 a month to rent it...
    bob
    Dec 2014
    Thanks so much.
