Taig lathe cross slide wheel
Results 1 to 3 of 3
Thread: Taig lathe cross slide wheel
    Apr 2015
    Default Taig lathe cross slide wheel
    Howdy,
    Newbie taig lathe owner here.
    When I turn the cross slide wheel there is some free movement before the cross slide moves.
    Is this normal?
    Seems like it would be hard to know how far I have moved the cross slide based of the markings like this?
    Thank you!
    Member awerby's Avatar
    Apr 2004
    Default Re: Taig lathe cross slide wheel
    That's called backlash; it's normal. Just start counting from the point where the screw engages. As long as you keep going in the same direction, it won't accumulate.
    Apr 2015
    Thank you for the reply. That makes sense! =)
