Typing in "X1" shouldn't do anything, without a G-code command to go with it, like a G0 or G01. Have you got any modal commands set, or maybe an offset value?
In the steps per unit settings, what have you got? If your unit is a millimeter, then (assuming you're using the standard half-stepping Taig controller) it should be 314.96 (half) steps per mm.
