Results 1 to 3 of 3
Thread: metric t-slot
    soy
    soy is offline
    Jun 2012
    japan
    metric t-slot
    Hi
    Please teach me a CNC plan using metric aluminum t-slot. For example Misumi's 4080(mm) or 3060(mm) etc.
    As for the cut area size, I wish it is bigger than 450mm x 900mm.
    The fla100-00 is an ideal plan. But it's a design of an inch size, so it is difficult
    to buid it in metric.
    It is very difficult for me to get 8020's 1530series t-slot.
    Jan 2006
    Use the same plan, substitute metric parts for inch parts. Seems straight forward.
    Matt
    soy
    soy is offline
    Jun 2012
    japan
    Distance of a slot and a slot
    1530(inch)=38.1mm x 76.2mm
    4080(mm)=40mm x 80mm
    thanks, matt
    Since the distance of a slot and a slot is different about 2 mm, it seems to be difficult to build straight.
    Only a frame could be constructed.
    However, I think that the various mount parts in which the screw hole is opened does not suit.
    I am glad if 1530 and 4080 are the same sizes in fact.
  1. one slot is coded other slot is not there
    By cwaugs in forum GRZ Software- MeshCAM
    Last Post: 05-05-2011, 10:00 PM
  2. cutting a slot with a t-slot cutter
    By cncuser1 in forum Mastercam
    Last Post: 09-09-2008, 10:02 PM
  3. Metric or Fractional T-Slot material?
    By jeffmorris in forum Joes CNC Model 2006
    Last Post: 08-25-2008, 03:43 PM
  4. Coated Carbide 4Flute Endmill, 3Flute Slot Drill, or 2Flute Slot Drill?
    By weaston in forum General Metalwork Discussion
    Last Post: 04-11-2007, 10:00 PM
