Results 1 to 5 of 5
Thread: CNC design for consideration?
    Mar 2012
    uk
    Hi all, i'm a long time reader, first time poster. I have experience in CNC and own an A3 sized desktop one and want to upgrade with a new home build. Basically i just want to cut mdf and ply with it, speed and really tight accuracy are not really that important and I have yet to calculate my motor requirements except that I'm going nema 23 for size.
    I just wanted maybe a more experienced builder or anyone in the know really to have a look at my design and see if there is anything obvious that might hold my design back before I commit to ordering the parts.
    The goal was to create it as cheap as possible but try and keep rigidity. I've used 16mm multi-start trapezoidal lead screws on x, y and z. Fully supported 16mm rails on x and y and 16mm round rail on z. My main concern is the lead screws on x sagging?? The machine is 1500mm x 1000mm at the rails.
    Any advise would be greatly appreciated. Thanks
    May 2010
    Why not use steel square tubing? That material is a lot cheaper.
    Mar 2003
    Shelby Twp, MI....USA
    Personally, I'd try to move the screws down and out of the way, unless you want oil and or grease on your arms all the time from reaching over them.
    Feb 2012
    England
    I'd use 30mm or better for the bottom X-axis rails,keep with the 16mm as guide rails.
    May 2010
    I would make the machine with a consideration that all moving parts can be covered in nylon fabric sleeves.
    That will keep the abrasive dust off the bearings and make the machine run better/longer.
    So I would hide the screw underneath metal guides so it won't touch the fabric sleeve.
    1. fixture consideration
      By XXF in forum Mastercam
      Last Post: 06-21-2011, 11:05 AM
    2. Electronic components consideration in mechanical design
      By coykiesaol in forum Mechanical Calculations/Engineering Design
      Last Post: 10-26-2010, 11:27 AM
    3. Finding Engineering Design Software For Automatic Machine Design
      By hellokitty in forum General CAM Discussion
      Last Post: 01-06-2008, 01:39 AM
    4. Mach2 consideration questions
      By jevs in forum Mach Software (ArtSoft software)
      Last Post: 02-18-2005, 07:47 PM
    5. Designs for open source consideration
      By pminmo in forum General Electronics Discussion
      Last Post: 07-18-2004, 10:54 AM
