Hey guys. Just wanted to share this information with everyone. When building a frame using T-Slotted Aluminum Extrusions, the cost of the hardware can usually be an over-sight, and often is the culprit when your budget gets busted! We have the solution for you. Check them out at com - Your Leader in T-Slotted Aluminum Hardware | TNUTZ (518)-632-NUTS(6887) They are really a helpfull, and inexpensive option for the small consumer.
