Page 3 of 3 FirstFirst 123
Results 25 to 30 of 30
Thread: My extrusion cnc router
  1. #25
    Jun 2011
    What kind of budget did you plan for this project? thats if you dont mind revealing.
  2. #26
    Dec 2010
    Quote Originally Posted by 2006LJRubicon View Post
    Total project cost including software, machining costs, and all other related hardware is is topping out around $2200
    I really didn't plan a budget...R&D is hard to budget
  3. #27
    *Registered User*
    May 2009
    Quote Originally Posted by steeltoes View Post
    Nice build
    My first two CNC machines were build with aluminum / MDF & plywood and for my 3rd machine I plan to make it all out of 8020.
    Hopefully will tell us your experience about deflection and accuracy.
    Did you cut/drill the aluminum or you had it done in a machine shop?
  4. #28
    Dec 2010
    It was a machined by a buddy who does it for a living. Still had to pay for the labor though, but at least it was buddy price...
    If I had to doit again I would use extrusion from Misumi, there are various threads on this brand, I beleive it is a bit more cost effective. I ended up with only .010" difference between one end and the other, which was remedied by flycutting the surface of my substrate which is 1 1/2" high density particle board, sealed with poly on all sides.
  • #29
    *Registered User*
    May 2009
    Good job, thank you
  • #30
    Dec 2010
    I have a breathing CNC...
  • Page 3 of 3 FirstFirst 123
    1. Build Thread- Aluminium Extrusion CNC Router Build
      By joshendy in forum CNC Wood Router Project Log
      Last Post: 08-24-2012, 03:58 AM
    2. Need Help!- Need Extrusion
      By indydawg in forum Bending, Forging,Extrusion...
      Last Post: 06-29-2010, 10:01 AM
    3. Extrusion Help
      By wilson248 in forum Bending, Forging,Extrusion...
      Last Post: 04-15-2009, 10:16 AM
    4. DIY extrusion die
      By llilrex in forum Bending, Forging,Extrusion...
      Last Post: 09-29-2008, 04:12 AM
    5. T-slot Router Bed Extrusion
      By gotswrv in forum Want To Buy...Need help!
      Last Post: 07-10-2008, 09:16 PM
