Page 2 of 3 FirstFirst 123 LastLast
Results 13 to 24 of 30
Thread: My extrusion cnc router
  1. #13
    Dec 2010
    More updates
    Attached Thumbnails Attached Thumbnails My extrusion cnc router-imag0013.jpg
  2. #14
    Apr 2010
    Looks good! You are WAY ahead of me.
  3. #15
    Dec 2010
    The ball bearing carriers showed today...got them adjusted to the rail...now just waiting for the rest of the leg extrusion for the base...
  4. #16
    Dec 2010
    Here's an update on the Y axis...Hope the X goes this well...
    Attached Thumbnails Attached Thumbnails My extrusion cnc router-y_axis_plate.jpg
  • #17
    Dec 2010
    Got the electronics shelf mounted...getting closer
  • #18
    Dec 2010
    After much designing and machining cost here is my Z axis assembly
    Attached Thumbnails Attached Thumbnails My extrusion cnc router-z_axis_ball_screw.jpg
  • #19
    Dec 2010
    Got the table top finished this evening and ordered the vacuum blower, should be here end of next week
  • #20
    Registered Senna's Avatar
    Apr 2003
    With this last pic of the tabletop in place... it sure looks as if you have a minimal amount of clearance for the Z...? It could just be an optical illusion from the camera angle. What is your clearance...?
    Senna
    aka BOOMER52 >>> http://www.rcgroups.com/forums/member.php?u=159693
  • #21
    Dec 2010
    The top is elevated on rails, while the polyurathane is drying. I designed 4" of clearance...
  • #22
    Apr 2003
    Ahhh... good deal. Looks like it is coming together quite nicely...!
    Senna
  • #23
    Dec 2010
    I should be spinning steppers by the end of next week...
  • #24
    Registered LouF's Avatar
    Sep 2011
    Very nice looks good.
  • Page 2 of 3 FirstFirst 123 LastLast
    1. Build Thread- Aluminium Extrusion CNC Router Build
      By joshendy in forum CNC Wood Router Project Log
      Last Post: 08-24-2012, 03:58 AM
    2. Need Help!- Need Extrusion
      By indydawg in forum Bending, Forging,Extrusion...
      Last Post: 06-29-2010, 10:01 AM
    3. Extrusion Help
      By wilson248 in forum Bending, Forging,Extrusion...
      Last Post: 04-15-2009, 10:16 AM
    4. DIY extrusion die
      By llilrex in forum Bending, Forging,Extrusion...
      Last Post: 09-29-2008, 04:12 AM
    5. T-slot Router Bed Extrusion
      By gotswrv in forum Want To Buy...Need help!
      Last Post: 07-10-2008, 09:16 PM
