Results 1 to 5 of 5
Thread: Latest revision with extrusion
    Dec 2010
    Here is my latest revision...sorry just old school 2D
    Dual belt drives on the X Axis including the 3:1 ratio reduction
    Attached Thumbnails Attached Thumbnails Latest revision with extrusion-cnc_machine.jpg
    Apr 2010
    If the X-axis length is still 60" long, then you want a few more legs underneath your table. Find a relevant deflection calculator for the extrusion you are using, and see what your deflection is versus load. You will want to do this for both the X and Y axes.
    Dec 2010
    Ok..Im using the 8020 extrusion...thankyou I appreciate the info..
    Apr 2010
    The 80/20 deflection calculator is buried in their Tech Toolkit download.
    http://download.8020.net/Tech_Toolkit/Tech_Toolkit.zip
    Plugin your extrusion type, the unsupported span and the load, and it will tell you maximum deflection. In reality, cutting forces will increase your load (hopefully marginally), but you will still want to make sure that the deflection is well within your total error envelope. In other words, if you want to hold 0.003" or better tolerance, you can't use it all up with the deflection in the X-axis or Y-axis support beams.
    Note: if your drawing is roughly to the scale I think it is, then I'd worry that your Y-axis is also grossly under-sized as well as your X-axis. The upside is that you can add support legs to the X-axis, whereas the Y-axis has to work with a large unsupported span.
    Dec 2010
    Thankyou for the link.
    The software wont run on my machine something about Century Gothic Regular font
    1. Sprutcam Revision Level
      By saabaero in forum SprutCAM
      Last Post: 03-16-2011, 07:11 PM
    2. Title Size and Revision
      By jybute in forum Solidworks
      Last Post: 02-19-2010, 11:50 AM
    3. Change starting revision of sheet?
      By 80083r in forum Autodesk Software (Autocad, Inventor etc)
      Last Post: 12-09-2009, 12:10 PM
    4. G320X First Revision Manual
      By CoAMarcus in forum Gecko Drives
      Last Post: 08-05-2009, 07:35 PM
    5. MC9 POST for MACH3 - Updated Revision
      By chris59 in forum Screen Layouts, Post Processors & Misc
      Last Post: 10-13-2006, 07:55 AM
