Well there's the obvious, T slot has slots to bolt to saves precise drilling that would otherwise be needed. But imo standard weight profiles are not strong enough alone. So you should be looking at the heavy weight profiles which are not cheap.
Channel I can imagine on its own may resonate a fair bit.
