where to find aluminum t slot material?
Results 1 to 12 of 12
Thread: where to find aluminum t slot material?
    Jan 2014
    Default where to find aluminum t slot material?
    Hi all, I have a 3020 chinese cnc. My aluminum t-slot has gotten a bit damaged over time and I'm curious where I can find the same aluminum t slot I have on it now. Any suggestions would be greatly appreciated. Thanks again! You all are great!
    Nov 2013
    Try Mc master carr
    or MSC for mail order
    Nov 2010
    Try Misumi or Automation4Less. Both are real easy to deal with.
    And then there is always 8020inc on ebay. I've bought many things from them. Good prices, but brace yourself for the shipping cost.
    Fractional Metric Profiles Fasteners T-Nuts Brackets items in 8020 Aluminum T-slot Extrusions store on eBay!
    Nov 2012
    canada
    If you contact bosch rexroth, or 8020 t-slot from their website they will direct you to a local supplier.
    Apr 2006
    Default Re: where to find aluminum t slot material?
    I use Faztek extrusion, via Amazon. It ships free with Amazon Prime.
    Amazon.com: faztek
    Best,
    JBR
  7. #7
    Jan 2015
    Hi guys,
    I am preparing my first CNC on the drawing board, love to read this forum while doing so. I am very interested and thankful about the links you guys posted here. I was wondering if you knew were to find metric aluminium extrusion files for Sketchup. Parker IPS have a few files, very helpful, but they are missing pieces and everything is in imperial units, which is kind of an problem for me.
    Thank you for your help
    Cheers
  8. #8
    Feb 2016
    Hiroshiman,
    Try www.8020.net - they have downloads of all there aluminum extrusions material. I believe you can create the size in metric then download.
    Thanks,
    Dave
  9. #9
    Nov 2007
    Or here. Buy direct from them. Pretty much any size you want.
    Framing Tech
  10. #10
    Mar 2014
    It looks like 8020.net updated their website. Last time I tried to order directly from them they referred me to the nearest engineering affiliate to order through. I just put together an order and progressed through the the shipping phase of checkout and it was pretty user friendly.
  11. #11
    You can purchase directly from 80/20 Inc. now, but you will be paying full list price. If you buy from a top tier distributor, you can usually negotiate a discount. We support CNC builders nationwide, and your order ships directly from the factory to your location. Visit the F&L Industrial Solutions store at F&L Industrial Solutions, Inc. | T-Slotted Aluminum Extrusion Experts to save 10% on all your 80/20 needs - just use this discount code at checkout:
    cnc10off
    In our opinion, 80/20 offers the highest quality t-slot extrusions available with superior anodizing/color - and very tight tolerances, so you won't be disappointed when you measure your new machine for mechanical slop after its all built.
  12. #12
    Jun 2012
    It's unlikely the OP's Chinese machine used 8020 extrusions.
