Results 1 to 2 of 2
Thread: Machining Ti
    Sep 2006
    Machining Ti
    I have attached 4 photo's of a X4plus machining a clock escapement wheel.
    25mm dia. 30 teeth
    Material is Ti 1.1mm thick.
    1mm dia. tc endmill, 0.2mm per depth of cut @ 2200RPM 30mm/min feed rate and lots of WD40 as coolant.
    I bonded the blank onto a piece of smooth plastic using constrution strength LocTite, but the wheel became loose before the final 4 teeth were finish, it's not good practice to hold down such a small component with ones finger on a CNC machine, it also gets hot, ouch!!
    The next one, I used Super Glue bonded onto a piece of brass plate, this worked much better, with a little help from a small screw driver broke the bond.
    Martin
    Attached Thumbnails Attached Thumbnails Machining Ti-ferris_wheel_clock_003.pdf   Machining Ti-ferris_wheel_clock_007.pdf   Machining Ti-ferris_wheel_clock_009.pdf   Machining Ti-ferris_wheel_clock_011.pdf
    PEU
    PEU is offline
    Registered PEU's Avatar
    May 2005
    Buenos Aires - Argentina (I like Ribs)
    Nice!
    For works like this one is where the speedmaster helps a lot, but given enough time as you demonstrated, it can be done on a regular sx3 or x4+ too.
    on a side note, there is no need to convert photos to PDF to upload them, just resize to something like 800x600 or 1024x768 and use the same method of upload.
    Pablo
  1. machining
    By mike hide in forum CNC Machining Centers
    Last Post: 08-10-2008, 09:19 PM
  2. 3d Machining
    By elogicca in forum LinuxCNC (formerly EMC2)
    Last Post: 03-07-2008, 10:51 PM
  3. MIS CNC Machining and tooling - General machining - Thermoform Molds
    By modernprecision in forum Employment Opportunity
    Last Post: 11-23-2007, 11:05 PM
  4. Machining anodized parts or anodize after machining?
    By SRT Mike in forum General Metalwork Discussion
    Last Post: 03-12-2006, 12:22 AM
  5. Machining Help!
    By Al_The_Man in forum General Metalwork Discussion
    Last Post: 11-12-2005, 04:15 PM
