finally got the missing cables (Thanks Xushuo!) I just opened the back of the SX3 for the 1st time since I puchased the machine
I have some questions:
1) the bottom board its of no use now right? [EDIT] YES IT SHOULD BE REMOVED, ITS REPLACED BY THE PIGGYBACK BOARD OF THE MOTOR CONTROL
[edit resolved]
2) The board is marked like this in the Motor Board I received (checked an X4+ from which I extracted the motor and its the same)
but, the cabling that comes from the motor (pulled from an X4+) is wired the oposite:
Which one is correct?
Other than that the mod seems straightforward, I think I will adapt the new front panel electronics in the old panel to keep the aestethics
Pablo
LinkBack URL
About LinkBacks
