Results 1 to 3 of 3
Thread: Syil SX3 spindle play and fix
    Oct 2006
    UK
    I notice there's quite radial play of the SX3 spindle. I hold the spindle lower end (the tool holder) with one hand and hold the top end with another. One hand pushes, one hand pulls, then reverse push-pull, I can feel the play. I don't think this is normal. Before I strip it down to find out the problem, did any one fix such problem before? or any recommended way to tight up the spindle?
    Many thanks
    David
    Jul 2006
    I do not think it is normal at all.
    Mine has no noticeable play, though I'm sure if I put a DIT on it and gave it a go we would find something.
    Registered ataxy's Avatar
    Jul 2005
    canada
    you sure its not the z gibb that are loose
    The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
  1. Problem- Syil Spindle has quit working
    By marco928 in forum Syil Products
    Last Post: 03-16-2010, 02:01 AM
  2. spindle to pully play jhead
    By andrewbishop66 in forum Bridgeport and Hardinge Mills
    Last Post: 06-01-2009, 07:56 AM
  3. Problem- Syil X3 Erratic Spindle Speed with Mach
    By reithguitars in forum Syil Products
    Last Post: 07-16-2008, 11:20 AM
  4. Syil X3 Mill Spindle Speed Calibration Procedure
    By Chrisjh in forum Syil Products
    Last Post: 01-12-2008, 02:54 AM
  5. Super X3 spindle controller (by Syil)
    By ints99 in forum Syil Products
    Last Post: 12-10-2006, 05:35 AM
